LT1 MAF routing issues
Old Mar 22, 2013 | 01:56 PM
pimpimusmaximus's Avatar
Car: 1984 Z28 T-TOP
Engine: 355 Lt1 w/Hotcam
Transmission: TH700R4
Axle/Gears: 3.73 4th gen limited slip
I have a 94 LT1 I am putting into my 84 Z28. I bought the a/c relocation bracket from bowers race and rod.
http://www.bowersrodshop.com/index.p...d=66&Itemid=53
I am keeping the thirdgen radiator. I am having a hard time fitting the intake elbow due to the radiator lines. Does someone make a kit for a 90 degree down intake kit w/MAF? Or, can I modify a "ram air box" to go with my Ram Air Hood?
http://www.hawksthirdgenparts.com/pr...tyle-Hood.html = hood
http://www.classicindustries.com/fir...s/f939705.html = air box
Says it's for MAS (I think also called MAF). I have heard these are more for the speed density engines. If it will be large enough for the maf I can make it a true ram air. Bwahaha!!
Old Mar 22, 2013 | 03:04 PM
92droptopws6's Avatar
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
Re: LT1 MAF routing issues
You can switch to speed density, just specify SD tune when you have your pcm tuned
Old Mar 22, 2013 | 03:07 PM
Car: '88 Trans Am
Engine: 5.7L TPI
When you have your PCM tuned have the MAF deleted and run it in speed density mode.
Old Mar 22, 2013 | 03:36 PM
Car: 1984 Z28 T-TOP
Is it really that easy? Once I have it tuned to SD I can just change to a ram air style filter? even with a cam and roller rocker upgrade?
Old Mar 24, 2013 | 11:07 AM
Firebat's Avatar
You may lose a few benefits if you lose the MAF. I think mileage is the big one. Look into using the 95 LT1 corvette intake bellow for the ram air box, that may be your best shot of getting the MAF to work with the ram air. The vette bellow goes straight out from the throttle body (not 90 to the side like the f-body elbow) and has a hole in it to hold the IAT sensor.
Old Mar 24, 2013 | 11:37 AM
Car: '88 Trans Am
Engine: 5.7L TPI
Yes it is simple.... just remember 92-93 Lt1s were SD aswell. The ONLY real drawback to having SD is if you already have the pcm tuned for it then you change the camshaft or something drastic of that nature you will need a re-tune...
NOW......if you choose not to delete the maf you can use the cheaper Ls1 boot from the Throttle body to maf then use a small coupler to a ram air box then instal the IAT into the box.....
Old Mar 27, 2013 | 03:55 PM
Car: 1984 Z28 T-TOP
ok, well I am going to keep the MAF and an installing a RAM air kit. I'll MacGuyver it in there if I have to. I kinda like the thought of having a functional RAM air hood and a beast beneath it to boot.
specialized
Jun 18, 2022 09:26 AM
777Shock777
Oct 29, 2015 04:30 PM
NBrehm
Aug 25, 2015 11:49 PM
Bert87
Aug 23, 2015 03:50 PM
mdtoren
Aug 23, 2015 12:52 PM
