Cammed ls1, safe to drive without tune?
Car: 85 camaro z28
Engine: 355
Transmission: t-5
I have a stock ls1 I'm building with a vengeance racing vindicator cam, stock head modification of dual springs/retainers, and hardened pushrods only. I'm just trying to get some knowledge here to make me less worried.
Is it safe to drive the car untuned without doing WOT or hard driving(light cruising only) for about an hour and 50 minutes to get to the tuning shop? I don't want to hurt the engine.
Car: 2000 Camaro SS/86 Iroc/89 Iroc(x2)
Transmission: 6 Speed
Axle/Gears: 4.10
Re: Cammed ls1, safe to drive without tune?
Yes you can, the driveability won't be great at all and you won't want to do any WOT pulls but you'll be fine. Also, swap the Injectors out (if you have any) at the tuner's shop so you won't run too rich on the way there.
-Matt
-Matt
Car: 85 camaro z28
Engine: 355
Transmission: t-5
You mean change the injectors beforehand and then drive it to the shop?
Transmission: 4L80E/4L80E
No, what he's saying is drive it to the shop with the original injectors, swap to the new injectors at the shop, and then have them tune to the injectors you're going to run.
Car: 85 camaro z28
Engine: 355
Transmission: t-5
Car: Camaro
Engine: 6.2L
Car: 92 Ttop Z28
Engine: Cammed 6.0
Axle/Gears: Built 10 bolt-3.90s w/ PBR discs
Wouldn't be surprised if your tuner puts a fresh set of plugs in either. Keep it easy and you'll be ok.
Axle/Gears: 4.10
Car: 85 camaro z28
Engine: 355
Transmission: t-5
Unrelated question to my previous,
The car has 305 carb hard lines, are they ok to use with a-n fittings?
I have the impression that using a high pressure external pump near the tank would supply adequate fuel to the engine, regardless of the line size?
The hard portion of the carb lines are fine. The rubber parts will only handle return, not supply pressure.
I put an EFI pickup with Walbro 255 in my carb tank, ran line with flared fittings to a Vette filter in the normal 3rd gen location, then picked up the factory carb line again up to the engine. My car was originally V6, so the line went up to the driver side of the engine.
I'd keep the line size at least 3/8" for the supply.
Car: 85 camaro z28
Engine: 355
Transmission: t-5
I'd keep the line size at least 3/8".
This is probably the closest, and no photos:
https://www.thirdgen.org/forums/ltx-...p-17-days.html
Post #7.
Post #7.
Car: 85 camaro z28
Engine: 355
Transmission: t-5
Post #7.
Post #7.
Into the tank, yes, although the carb'd tank doesn't have the baffles that the EFI tanks had. Hasn't seemed to cause any issues.
As for the wiring, no, that wasn't "direct fit". I spliced the EFI pickup wires for the fuel gauge into the factory chassis harness, and ran new wires for the fuel pump.
Car: 85 camaro z28
Engine: 355
Transmission: t-5
awesome, I'm gonna go with that setup then. Hopefully I don't encounter any issues either.
Car: 1986 Firebird
Engine: 6.0L LSX
Just FYI, if you are using your stock carb fuel sender, you will need to trim the pickup tube a couple inches to fit the walbro pump.
If he does what I did, he'll be putting the Walbro pump into an EFI pickup assembly and installing that into the carb tank.
Car: 86 z28
Engine: Hyd. roller 498
Axle/Gears: 12 bolt 3.90 gears
Car: 85 camaro z28
Engine: 355
Transmission: t-5
Car: 85 camaro z28
Engine: 355
Transmission: t-5
Was it cammed? Mine has 240/244 .605/.596 and 112 LSA. I hope it doesn't stall out everytime I come to a complete stop on the way there.
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
I went frm bone stock ls1 to a lq4 with cam and intake,it ran on the stock tune for 3 weeks daily without issue..but did stall at stoplights depressing the clutch.Right now im driving mine untuned again after doing a head swap on the lq4,went from 317 head(9.6:1) to milled 243 heads(10.6:1) and it runs good but stalls again at a stop.Just take it easy and do as suggested before.Change oil etc at the tuner..it will be worth it feeling how it drives now vs tuned is night and day.
