Dakota Digital & E-Rod
Transmission: 4L80E/4L80E
Dakota Digital uses their own sensors for engine temp and oil pressure. Voltage comes from the chassis harness.
Tach would be the only input needed from the module, and I haven't seen any information about that. I'd be surprised if it didn't have a tach output, though.
Car: 2012 F350 lariot/1991 Camaro RS
Engine: Powerstroke/6.0
Transmission: 6R100/4L80e
Axle/Gears: 3.73/3.42
Re: Dakota Digital & E-Rod
im using the Holley hp EFI and the j2 adapter with the outputs to use for the dakota digital I can use the factory sensors to run the ecu but can change the values of the outputs to match what DD needs for the proper readings
