83 LT1 swap question
Old Apr 17, 2013 | 02:37 PM
Strick1's Avatar
Car: 92 Vette, 83 Camaro
Engine: 305 going to 95 LT1
Transmission: 5 speed going to T56 6 speed
Axle/Gears: 3.73 posi with disc brakes
Looking at my K-member, there doesn't seem to be enough room to cut a notch in it for the A/C compressor. Am I missing something?
Old Apr 17, 2013 | 05:56 PM
jaysfs's Avatar
Car: 91 z28, 07 trailblazer ss
Engine: lt1lt4 hot cam,ls2
Transmission: t56
Re: 83 LT1 swap question
From what ive read is that in order to use the camaro a/c you have to use the lt1 motor mount and that will move back acouple inches. Then you can notch it
Old Apr 17, 2013 | 08:03 PM
Strick1's Avatar
So, if I use the Caprice Compressor (LT1's) I don't need to notch the K-member? That would be nice.
Old Apr 19, 2013 | 05:00 PM
Strick1's Avatar
I guess there are not many guys interested in this any more. I don't seem to get any replies. Oh well.
Old Apr 19, 2013 | 05:18 PM
jaysfs's Avatar
Transmission: t56
From what ive read you can even take a ballpeen hammer and make room for the ac.it wouldnt be that bad.for this summer im just running the ac delete so my lt1 just.dropped.right in
Old Apr 19, 2013 | 08:08 PM
WhiteBlaze's Avatar
Car: 1984 Firebird
Axle/Gears: 3.42's
You use stock 3rd gen motor mounts, not the LT1 mounts. I heated up my k member and hit it with a hammer for the compressor to fit.
Old Apr 20, 2013 | 06:49 AM
Strick1's Avatar
In my picture, that is a stock 3rd gen motor mount. Do I have to modify the motor mount to allow the LT1 compressor to fit?
Old Apr 20, 2013 | 06:53 AM
Strick1's Avatar
Running without A/C down here in SC is a crisis situation. After looking carefully at the K-member once the engine was removed, I see that there isn't room to notch the member because of the motor mount.
What have I gotten myself into?
Old Apr 20, 2013 | 06:59 AM
cprmn14's Avatar
Car: 91 RS
Engine: LTwon
Axle/Gears: Both
Alot of the questions your asking can be found with a simple Google search or just reading through FAQs and sticky threads. Any question you can think of for your swap has already been asked and answered somewhere out there. People just like progress and pics.
Old Apr 20, 2013 | 07:02 AM
cprmn14's Avatar
Car: 91 RS
Engine: LTwon
Axle/Gears: Both
https://www.thirdgen.org/forums/ltx-...-k-member.html
Found this in about thirty seconds.
Old Apr 20, 2013 | 07:23 AM
Strick1's Avatar
I've read this thread over and over, but it's really for a LS1 not an Lt1. And if you look closely at the K-member notch and then look at my K-member with the motor mount installed, I don't have room for that notch pictured in the thread.
Old Jan 11, 2014 | 11:43 AM
Strick1's Avatar
Let me finish this thread with this; I found a 94 Corvette accessary set up and bought it. It puts the ac compressor on the driver's side up high. Just look at a 92-96 Vette. So, I will not be knotting my K-member and I'll have more room for my headers. Thanks guys
midge54
Sep 2, 2020 07:13 PM
midge54
Dec 27, 2019 04:14 PM
midge54
Jan 29, 2017 07:00 PM
redmaroz
Aug 16, 2015 11:40 PM
sreZ28
Aug 14, 2015 07:48 PM
