Hooker P/N: 12621HKR mounts
Old May 14, 2013 | 08:32 AM
utfan01ss's Avatar
Car: 89 IROC-Z
Engine: 355ci SBC
Transmission: TH700R4 - 2500 stall
Axle/Gears: 3.70 9 bolt
Anyone use these Hooker LS swap motor mounts on their conversion? Tennessee Speed Sport told me about them, said I wouldn't have to change my frame mounts with these Hooker swap mounts. Evidently they bolt to the LS block and act as a clamshell.
Just curious if they work and align the drivetrain properly. Meaning if I use a Spohn T-56 crossmember it'll line up without any issues.
Old May 21, 2013 | 06:02 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
http://www.holley.com/data/Products/...564rev1%20.pdf
12621HKR (MOVES TRANSMISSION 1.25” FORWARD AND .5” UP FROM STOCK LOCATION)
NOTE: This 12621HKR engine swap mount kit is designed to locate a GEN III/IV (LS Based) engine so that the transmission bellhousing is located 1.25” forward from its original position when installed with a standard small block Chevy engine using stock clamshell style mounts.
NOTE: Due to the engineered raising of the engine by .5”, the rear pinion angle may need to be modified if increased drivetrain vibration is experienced after installation.
I don't think that's what you want.
Old May 25, 2013 | 11:45 AM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Hooker P/N: 12621HKR mounts
Just grab some of the 1" setback plates that various vendors sell. allows you to reuse the upper and lower mount pieces and puts the engine in the correct positioning for trans/driveshaft
Old Sep 7, 2015 | 05:17 PM
monkey-leader's Avatar
Engine: 6.0L LY6 (Vortech Supercharged)
Transmission: Tick Performance T-56
If you swap sides it does the opposite...
IE moves the engine 1.25" back
Hotrodboba400
Dec 10, 2019 07:07 PM
ynk1121
Sep 12, 2015 12:27 AM
hdis2002
Sep 8, 2015 02:52 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
