wiring up maf
Old May 15, 2013 | 12:05 AM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
wiring up maf
I have a concern on my car. I bought it from a member on here and he deleted all the wiring for the MAF but now im wanting to intall the maf but im not sure how it would be wired up. Would i have to wire it like stock from a 4th gen?
Old May 15, 2013 | 04:46 AM
86White_T/A305's Avatar
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
Re: wiring up maf
I would start at the pcm..see if the maf wiring was de-pinned first and run new wires to the maf.Trying to find wires cut off in the original harness can be a pain.Then have the pcm tuned for maf again.
Old May 15, 2013 | 08:55 AM
25th327RS's Avatar
Car: 92 Ttop Z28
Engine: Cammed 6.0
Axle/Gears: Built 10 bolt-3.90s w/ PBR discs
Re: wiring up maf
What PCM do you have, and which MAF do you want to run? If you don't have anything as of now, may be a good time to be a 5wire truck MAF.
Old May 16, 2013 | 04:13 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: wiring up maf
i have a 00fbody pcm and no wiring at all for the maf. I have the three wire maf
Old May 16, 2013 | 05:09 PM
25th327RS's Avatar
Car: 92 Ttop Z28
Engine: Cammed 6.0
Re: wiring up maf
On three wire MAF for 99-02 Fbody PCM:
Black wire-ground
Pink wire-ign 12v
Yellow- red plug, pin31 on PCM
Also required is air Intake temp sensor:
Tan-red plug, pin 25
Purple-red plug pin 57 on PCM.
If you are interested in using the larger 85mm 5 wire truck MAF, a separate IAT sensor is not needed, as its incorporated into the MAF. I have a hand drawn diagram on wiring up the truck MAF to a ls1 Fbody PCM if you'd like, but its basically matching the IAT and MAF colors from the ls1 sensors to the truck MAF.
Old May 16, 2013 | 11:18 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: wiring up maf
i have the iat in the car just dont have the maf wired up...
Old May 16, 2013 | 11:20 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: wiring up maf
Black wire-ground
Pink wire-ign 12v
as for the pink wire on the ign is that one on the pcm as well?
Old May 16, 2013 | 11:23 PM
Engine: 2005 LQ4
Axle/Gears: 3:54
Re: wiring up maf
doesnt have to be..as long is its 12v ign hot in run.grab it from wherever you want..main coil harness is right there.
Old May 17, 2013 | 12:42 AM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: wiring up maf
Oh ok so to point out my doubts and questions
the black wire i put it on any ground
the pink wire to a ign 12 v
and the yellow one to my pcm on the 31 pin that is all that is neeeded to wire it up?
i thought i needed to put it to a relay or something since i looked at the diagram of it and it says to a fuse so that had me confused
Old May 17, 2013 | 10:24 AM
25th327RS's Avatar
Car: 92 Ttop Z28
Engine: Cammed 6.0
Re: wiring up maf
It's a good idea to hook the pink wire through a fused ign 12v source, but not manditory.
Old May 20, 2013 | 12:30 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: wiring up maf
OK i got the wiring done thanks to TPI TERROR cars engine bay looks alot better and runs better too
Old Sep 5, 2020 | 02:23 AM
rololara's Avatar
Re: wiring up maf
Black wire-ground
Pink wire-ign 12v
is this the same for a 98 pcm ? I am having problems with the maf, I already change it 3 times and none of them worked, so I figured out that maybe the wiring has a failure so I’m looking to a diagram or something to connect directly the maf to the pcm
89GTAOz
May 16, 2020 09:31 AM
trevor1010
Aug 26, 2015 02:41 PM
trevor1010
Aug 24, 2015 08:34 PM
trevor1010
Aug 24, 2015 11:29 AM
Bert87
Aug 23, 2015 03:50 PM
