Cable speedo with 4L60E
Car: 86 Z28/86 IROC
Engine: 305 LG4/ LT1
Transmission: 700R4/4L60E
Doing an LT1 with 4L60E swap and have a cable speedo, how do you get the speedo to work?
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
Re: Cable speedo with 4L60E
You will need to replace the tail housing of the tranny from a electric output sensor to a mechanical output shaft.
Car: 86 Z28/86 IROC
Thanks, i pulled the housing of my 700R4 to put on the 4L60E, the 4L60E has a metal straight gear that the sensor reads off of i guess while the 700R4 has a plastic gear that the gears go on an angle, do those need swapped too?
Car: 86 Z28/86 IROC
Got a gear puller and swapped the gears, shes ready to be dropped in now... Thanks for the help!
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
the ecm needs that VSS signal to make the trans shift properly, tell it when to lock up the toque converter, and trim the timing and air/fuel mixture for better fuel economy... you can get a box from somewhere that takes the vss signal or the speedo output from the ecm and drives a mechanical speedometer...
Car: 86 Z28/86 IROC
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
You would need something like this to make it work with your particular LT1 4L60E:
Reluctor ring adapter
Car: 1984 Trans Am
They also have a housing that connects to the VSS for the trans shift points.
Car: 1984 Trans Am
Transmission: 4L80E/4L80E
Holy 4-year-old thread, Batman!
Car: 1984 Trans Am
Car: 1984 Trans Am
I"m also in the middle of doing this right now. I think I have it figuredout and I'll post pictures/thoughts once i get it sorted.
Z28/ZR1
Oct 23, 2015 01:04 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
rs_z28_vert
Sep 30, 2015 09:47 PM
