Fuel pump relay control wire
Old Aug 2, 2013 | 08:08 PM
Redwhisper's Avatar
Car: 86 IROC-Z
Engine: 97 LT1
I have a 97 LT1 in my 86 Camaro that isn't getting fuel. If I put power to the relay it closes and starts the pump. I have read many posts and thought the green/white wire from C220 lable fuel pump relay control was the right wire, but with the ingnition on it does not have power. Before I tear the harness apart to follow the wire back and check its continuity could someone confirm that this green/white wire is the "trigger" that will close the relay.
Old Aug 2, 2013 | 08:37 PM
89rs454's Avatar
Car: 1989 SS
Engine: LT1+1500$ hooker exhaust
Axle/Gears: 3.42 bogger
Re: Fuel pump relay control wire
Don't know if i will be much help, but i have a thread on this, yours being 86 i doubt it, but here is my wiring thread, post #20.
https://www.thirdgen.org/forums/ltx-...stock-lt1.html
c100
PIN A-Power feed from injector fuse 9 going to a switched 12v source
PIN G-Power feed from ignition fuse 11 to a switched 12v source
PIN K-Power feed from injector fuse 10 to a switched 12v source
c105
Power feed from Fuse #10
(injectors 1995/eng sensor 96-97)
c210
PIN A-Starter 12v source to B4 C100 Starter wire(purple)
C220
PIN J-Fuel Pump Relay Control to G4 of c100 Fuel Control gray wire
C230
PIN G-Power feed from ecm ign fuse 5 to switched 12v
Old Aug 5, 2013 | 11:32 AM
25th327RS's Avatar
Car: 92 Ttop Z28
Engine: Cammed 6.0
Axle/Gears: Built 10 bolt-3.90s w/ PBR discs
The green/white relay trigger wire from the LT PCM sends a ground signal to the relay, not a 12v. That being said, just be sure the fuel pump relay you are using is a "ground triggered" relay.
RazorN8
Jan 7, 2022 11:44 AM
Infested
May 22, 2018 11:56 PM
mustangman65_79
Apr 14, 2017 05:37 PM
justin57
Aug 20, 2015 07:05 PM
Kaweh
Aug 9, 2015 02:54 PM
