Temp sensor in ls3 engine
Old Aug 13, 2013 | 07:46 PM
Boreen's Avatar
For you guys that swapped in Ls engines. What temp sensor are you running in the cylinder head to read on the factory gauge. The head is metric threads, and with my engine already in and runnimg, I am not drilling and tapping a head or rethreading the hole with the sensor being at the back of the passenger head.
I bought a sensor with metric threads that's a one wire hook up and it only works very very rarely. So that's no good.
If there's nothing I can buy for that, what aftermarket gauge for a pillar pod can I get that would have the metric threads to screw into the head?
Old Aug 13, 2013 | 09:18 PM
Lonnie P's Avatar
Car: 91 Formula
Engine: 2012 LS9
Transmission: 4L80E
Axle/Gears: Strange 60 3.54:1
Re: Temp sensor in ls3 engine
Buy a temp sensor for a 98 Trans Am.
It will replace both the factory ECM sensor & also provide an additional lead for the factory gauge. You will need the 3 prong connector for it also.
Old Aug 14, 2013 | 12:29 AM
Boreen's Avatar
Can this ls1 sensor be ran just for the factory gauge than?
I already have the factory ls3 temp sensor in the drivers side head and is connected (and working correctly) to my stand alone engine controller kit. So I don't wanna start messing with that stand alone harness if I don't have to.
Old Aug 14, 2013 | 08:11 PM
Lonnie P's Avatar
Car: 91 Formula
Engine: 2012 LS9
Transmission: 4L80E
I'm sure it will work fine with the 1 wire.
Old Aug 17, 2013 | 12:10 PM
Boreen's Avatar
Also, where can I get this sensor with the pigtail? Is this a three or two wire pigtail?
Can I run one wire off of it to the factory gauge and a wire off it to an Autometer short sweep temp gauge that I will be installing in my pillar?
I want the accuracy of the Autometer gauge, but I still want all my factory gauges to work as well. Unless I am asking too much by doin this
italiano67
Dec 11, 2016 09:21 AM
Caspar
Jun 19, 2016 11:19 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
timonator
Aug 11, 2015 09:56 PM
