ls 1 trans dipstick in iroc z
Car: 88 Iroc ls1 swap
Engine: ls1
Transmission: 4l60e
Axle/Gears: original disc
Does the ls1 dipstick fit in the third gen body fine has anyone had any trouble..??
Transmission: 4L80E/4L80E
It should fit, depending upon the mounts you use and where they locate the engine/tranny.
I used neutral location adapter plates for the front, and Hawks crossmember for the rear. The biggest problem I had was finding it in the storage unit after putting the engine/trans in there in December, and not getting around to installing it until August.
Engine: ls1
Transmission: 4l60e
Re: ls 1 trans dipstick in iroc z
I bent mine...:-( ... im using hawks motor mounts and spohn ctossmember.. With saftey loop thanks,for any help...!!!
Your 700r4 dipstick will look the best in the engine bay. The hold down will not reach a bolt though, so you'll have to figure out a mount. I used a conduit clamp on the rear of the cyl head
The fbody ls1 4l60e dipstick fits, but was designed to go under the long cowl 4th gens had. It looks bad. Trucks equipped with the 4l60e look better
Looks - doesn't matter to me if it works. I'll take looking bad over rigging up something.
Car: '91 Camaro
Engine: LSx
Transmission: 4l60e
Axle/Gears: posi
just an fyi the tahoe dip stick also works with some, very little, tweeking to fit under the hood, a bit long but works and functions.
For whatever reason, I don't have a good picture of the 4th gen tranny dipstick, but here are what I do have.
Obviously, I'm a function-over-form guy (someday I'll get around to relocating the PCM, but that will be after the LS 403/4L80E in the '57 is running). But, I don't see what the issue is with the way this dipstick "looks".
Car: 86 IROC-Z, 98 Z28
Engine: 370 LSx, LS1
Transmission: T56's
Axle/Gears: 3.73, 3.42
I think either looks fine, haven't seen the lokar one though. I had a heck of a time installing the 4th gen dipstick with the motor and trans already in the car though. Took me forever lol
Engine: ls1
Transmission: 4l60e
Thanks alot ..!! Really apprecite the pics and the time you took to help ima try my 700r4 for now didnr know it would work... Since i bent my 4l60e... Thanks again..
Engine: ls1
Transmission: 4l60e
Engine: ls1
Transmission: 4l60e
Car: 1989 IROC LSX
Engine: Swapped LS6 Forged by LME
Transmission: 4L65E
I used the 700R4 tube and it was tricky. You have to trim the bracket a hair to clear the ribs in the bell housing and like stated earlier, the bracket does not realy have a place to bolt it to. I used the hole in the trans and braced a nut in it with a roll pin to secure it. (pic). Also With my set up there is no R&I of the tube with the eng. and trans installed. I have to pull the trans to get the tube in or out. BUT IT WORKS
Car: 1988 Chevy Camaro
Axle/Gears: 10 Bolt 28 spline, 3.73
This is only $36.99, and looks just like the lokar one. Just ordered it and should get here in a few days.
http://www.cfrperformance.com/CHEVY_..._p/hz-3006.htm
maroe624
Apr 16, 2017 08:29 AM
mustangman65_79
Aug 11, 2015 03:17 PM
