O2 sensors questions, engine swap, help please
Old Sep 3, 2013 | 10:26 PM
john_rs25th's Avatar
Car: 1992 RS 25th anniversary
Engine: 5.0
Transmission: 700
Axle/Gears: 99 Z28 rear axle 3.23
Hi everyone, I need help, I´m making an engine swap to my 92 RS, I´m mounting a LS1, but I have a problema with the O2 sensors, the arness have four O2 sensors, but I want to know if is posible to jump or just not to connect the sensors, and if that action will affect the correct function of the engine, or it will be a problem with the HP´s, I hope you can help me, and understand what I´m trying to tell you, thanks for all.
Old Sep 4, 2013 | 01:01 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: O2 sensors questions, engine swap, help please
I believe the rear O2 sensors can be deleted with a custom tune in the PCM
(which you are going to need anyway with a retro swap )
Old Sep 4, 2013 | 06:00 AM
Jay_rich's Avatar
Car: 1987 Z28
Engine: 2005 5.3L, LS6 Cam
Axle/Gears: DTS 9" 3.50 TrueTrac
Yup just cut off the rear o2's and have them tuned out OR buy o2 simulators so the PCM thinks they are in place.
They will be wired as Bank 1 oxygen sensor 2, and Bank 2 oxygen sensor 2.
Jay
Old Sep 4, 2013 | 08:38 AM
Pocket's Avatar
Car: 91 Trans Am
It sounds like you're using the fbody harness mostly intact, so instead of cutting anything off, simply repin the fronts to rears as the front harness is too short for a conversion into a 3rd gen. Even swaps with manifolds must move the front O2s down the y-pipe
Old Sep 4, 2013 | 03:20 PM
86gn's Avatar
Car: 92 Vert
Good Idea,glad I seen this B4 I started on my wire!!
Old Sep 4, 2013 | 06:22 PM
Engine: 5.0
Transmission: 700
and what will happen with the now front, (before rear O2) I just let it disconnect or cut off, so somebody told me that it was necessary a new tune up to the PCM, so it si posible to made it on the dealer or where, cause here in mexico is a Little hard to find a place where to do it., thanks for your help.
Old Sep 4, 2013 | 06:30 PM
Pocket's Avatar
Car: 91 Trans Am
Order a tuning package and DIY
The old fronts are no longer necessary. Do whatever you want with them. I'd zip tie them out of the way vs cutting them off. I'm not a fan of leaving 12v wires free floating ESP in the vicinity of a ground wire that's also loose
Old Sep 8, 2013 | 10:19 AM
Pocket's Avatar
Car: 91 Trans Am
http://www.lt1swap.com/vortec_o2_sensors.htm
Heres the link to the O2 types and wiring differences
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
