Spohn K-member
Old Oct 1, 2013 | 08:30 AM
LastGTA's Avatar
Car: 92 GTA
Transmission: A-4
Spohn K-member
Have they fixed the fitment issues yet? I have seen their suspension in action on a local 3rd gen and I would really like to stick with them. If they still have the same fitment issues them I will most likely go with a BMR K-member, A-arms and coilover kit. I'm not a fan of mixing suspension components though. Also the BMR K-member will clear factory LS1 A/C correct?
Old Oct 3, 2013 | 07:21 AM
LastGTA's Avatar
Car: 92 GTA
Transmission: A-4
Re: Spohn K-member
So nobody has installed a spohn k-member recently??
Old Oct 3, 2013 | 02:18 PM
87CIZ's Avatar
Car: 88' Iroc-Z
Engine: LQ9
Re: Spohn K-member
its not the k member that had problems. it is the a arms. and im not sure that they fixed that.
Old Oct 3, 2013 | 05:26 PM
Flip 2's Avatar
Car: 1983 Firebird SE
Engine: C5 LS1
Transmission: 6 speed
Re: Spohn K-member
A/C fits BMR
Old Oct 3, 2013 | 07:54 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
Re: Spohn K-member
I was told that the A/C didnt fit BMR by BMR. maybe they changed the design. Is your A/C in the Stock LS1 location?
Old Oct 3, 2013 | 08:00 PM
Rich92 RS's Avatar
Car: 86 IROC-Z, 98 Z28
Engine: 370 LSx, LS1
Transmission: T56's
Axle/Gears: 3.73, 3.42
Re: Spohn K-member
People also had trouble with either the center link, or tie rods rubbing on the Spohn Kmember. BMR or UMI would be a better choice. Though with UMI you cant run the AC compressor in the stock LS1 location.
Old Oct 3, 2013 | 09:01 PM
Flip 2's Avatar
Engine: C5 LS1
Re: Spohn K-member
I have a C5 LS1. The Corvette accessories are 3/4" closer to the engine. I had to do some work to fit mine. Heard from other folks their F-body compressor fit ok.
Spohn, no way. UMI says no. BMR being conservative, telling folks no??
BTW, I'm also using the "Bat Wing" oil pan.
Old Oct 4, 2013 | 07:25 AM
LastGTA's Avatar
Car: 92 GTA
Transmission: A-4
Re: Spohn K-member
Thanks for the input. I hear mixed results on BMR with A/C. I would be running stock LS1 A/C but that's the last of my worries. I want the motor and K-member to fit with minimal effort. Looks like BMR K-member and A-arms are the way to do.
Old Oct 4, 2013 | 11:12 AM
Pocket's Avatar
Car: 91 Trans Am
Re: Spohn K-member
I'm running a corvette Ac compressor and had to notch the spohn a-arm box. The notch was deeper than 3/4" so a fbody compressor would need a trim to fit too. That's with the mounts I built, not sure using spohn mounts. Threw them in the scrap bin
Old Oct 5, 2013 | 06:10 PM
rickyzZ28's Avatar
Car: 1990 RS
Axle/Gears: 3.73 9 bolt
Re: Spohn K-member
I have the BMR k-member and their a-arms with QA1 coil overs from Spohn. Mine fits great and I do have working AC with the LS1 f-body setup. Only problem I had was I could not get my poly mounts to fit in the BMR k-member so I had to run stock ones. Others have them, but mine would not fit and I tried everything when I had the cradle on the floor and they would not fit. I am not saying it was the k-member as it could have been the mounts though, because when I put the stock mounts back it, the motor dropped right on.
Old Oct 10, 2013 | 08:25 PM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
Re: Spohn K-member
Spohn is garbage. BMR clears LS1 A/C. I'm running stock motor mounts. Iirc, the BMR install instructions have the wrong torque specs (like 2x what it should be) printed for the k-member.
Old Oct 15, 2013 | 12:40 PM
LastGTA's Avatar
Car: 92 GTA
Transmission: A-4
Re: Spohn K-member
BMR it is guys. I have decided to run BMR K-member and A-arms with Spohn's coil over kit. Thanks for the input.
darwinprice
17
Oct 11, 2015 11:51 PM
Nervous2
Oct 8, 2015 10:53 PM
matt's 91rs/tt
LSX and LTX Parts
Oct 8, 2015 06:11 AM
luvofjah
Sep 26, 2015 08:28 PM
Mdenz3
Sep 17, 2015 08:36 AM
