Help with pedals
Old Oct 22, 2013 | 04:54 AM
86gn's Avatar
Car: 92 Vert
Help with pedals
Changing from a auto to 6speed , have a set of 3rd gen pedals what all switches do I need for the pedals for this swap . 1992 rs ..
Old Oct 22, 2013 | 07:30 AM
LastGTA's Avatar
Car: 92 GTA
Transmission: A-4
Re: Help with pedals
I just pulled my manual pedals out. There is a clutch engagement switch on the clutch pedal. Looks like that's it.
Old Oct 22, 2013 | 09:19 AM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
You need the clutch safety switch (clutch position switch), which as long as the pedals are from a 87+, the clutch switch is the same from 87 - 02 I think. Dont quote me on the years, but at some point the switch was different.
The older pedals had a different style switch.
You'll want the clutch anticipate switch if you have or want cruise control. Otherwise, just the safety switch and the brake switch.
J.
Old Oct 22, 2013 | 04:18 PM
86gn's Avatar
Car: 92 Vert
thanks guys , any way to tell the difference in the years on the pedals...not sure the year they came out of
Old Oct 23, 2013 | 06:43 AM
Car: 86 Trans AM
Just check out the way the switch mounts. I believe the older ones look metal and long, and the newer style sort of looks like a smaller plastic push button.
There will bee two holes, with slots below them so you can insert the switch, then slide it down to lock it into place. Ill see if I can dig up pictures. I tried to search yesterday...but the older style switch is difficult to find.
J.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
gmoutdoorsman
Oct 3, 2015 11:42 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
ironbmt
Sep 27, 2015 06:00 AM
Night rider327
Sep 2, 2015 04:18 AM
