5.3 vortec passlock
Old Oct 28, 2013 | 06:55 PM
adamrivera94's Avatar
5.3 vortec passlock
I have a 01 5.3 vortec in my third gen I thought I could put a vats bypass module but peaople are telling me it's not pass key it's passlock do they make a bypass module for 5.3 vortec? If so does anyone have a link for it?
Old Oct 28, 2013 | 08:51 PM
25th327RS's Avatar
Car: 92 Ttop Z28
Engine: Cammed 6.0
Axle/Gears: Built 10 bolt-3.90s w/ PBR discs
Re: 5.3 vortec passlock
Plain and simple rule is, if the donor PCM is from a car with a chip in the key, a module can be used. If the donor PCM is from a vehicle without a pellet chip in the key, it must be tuned out of the PCM, no module can be wired in.
Passkey- pellet chip in key
Pass lock- no pellet in key.
Any of the 99-up GM trucks or SUVs are a pass lock security system. You have to have the PCM tuned to get rid of vats, a module won't work for your situation.
Old Oct 28, 2013 | 09:22 PM
I was looking on eBay there's a few passlock modules on there?
Old Oct 29, 2013 | 09:22 AM
25th327RS's Avatar
Car: 92 Ttop Z28
Engine: Cammed 6.0
The way I understand it, the trucks use transponders to communicate and enable/disable vats. Even with a bypass, a thirdgen doesn't have all of the nessasary parts to make the system function.
It is plain and simple as sending the PCM out and having vats deleted.
That or buy a LS1 PCM and then wire in a bypass module.
Or have your PCM reflagged with a ls1 tune and then wire in a bypass module.
Neither of these are cost effective solutions to just having your PCM you already have sent out to have vats removed.
ZZ3Astro
Aug 13, 2019 12:57 AM
Quzyle
Oct 15, 2015 03:35 PM
customblackbird
Oct 1, 2015 04:30 PM
monte87cortez
Sep 26, 2015 08:10 PM
Amillionoh7
Sep 11, 2015 11:36 AM
