91Z28 LS1 Swap
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
Re: 91Z28 LS1 Swap
I had a trans cooler that I used on my other car years ago so I decided to use it on this car since I put a 3200 stall torque converter in. I mounted the trans-cooler then realized I had the wrong size of trans cooler hose. I'll pick up the right size hose later this week.
Next I need to figure out the vacuum lines/pcv system and heater hoses. Anyone have any input on the best way to do the heater hoses? I'm planning on using the stock 3rdgen heater valve. Looks like I will need some sort of T or reuse the stock metal heater hose line that ran along the passenger side?
Car: 1989 Pontiac Trans Am GTA
Engine: cammed LS1
Transmission: Monster SS 4L65E
Axle/Gears: 9 bolt posi w/ 3.70 gears
Re: 91Z28 LS1 Swap
Is that trans cooler going to get enough air flow being mounted to the back of the bumper like that? I like the idea though
Your swap is coming along nicely by the way! Real clean car.
Engine: cammed LS1
Re: 91Z28 LS1 Swap
I ran the small wires(original 3rdgen part of the harness) that go to the starter over top of the engine and down under the headers, that seems like the way it wanted to lay. Did you guys do it that way or down the backside of the engine? I tried it both ways, for now I have it going down the front of the engine. Its more hidden down the back of the engine but that area is crowded with wiring harness, grounds, and heater hoses. You can't see it in the pics though, I hadn't done that yet when I took the pic.
Re: 91Z28 LS1 Swap
Here's what I did for my heater hoses. I reused the stock hard line. Not sure if it would work with the headers though. I retained the stock heater valve as well. I can take a better, more current pic for you if you'd like.
If you have time get some more pics of your heater valve setup. Like you said though I'm not sure if that would work for me since I have headers but maybe if I located the valve more to the outside of the car it would be far enough away from the heat. Thanks for the comments and the help. My other LS swapped car doesn't have heat/AC and is carbed.... so much more simple.
Car: '88 Iroc-Z
Axle/Gears: 3.23 posi 10 bolt
Re: 91Z28 LS1 Swap
I used all the stock TPI hoses except those that went to the water pump: "heater core to steel pipe" (Dayco 88353), "heater core to heater bypass valve" (Dayco 87701) & "steel pipe to heater bypass valve" (Goodyear 4347). Then found molded hoses that were the right sizes & cut them to fit for the "heater bypass valve to water pump" (Dayco 87695) & "steel pipe to water pump" (Gates 28478). I bought some hoses from local part stores & ordered some from Rock Auto. They have good pictures on their web site.
Car: 91 Z28
Engine: 6.0L LQ9
Axle/Gears: Dana 44 3.92
Re: 91Z28 LS1 Swap
i believe ghettocruiser used a splitter from an astro van, it has 4 ports, so you don't need the metal tubing. that's what i will do when i add AC back to my swap.
Engine: cammed LS1
Re: 91Z28 LS1 Swap
I used a few of the hoses with a 90° elbow molded on one end. I'm sure most auto parts stores carry them. I got mine from Autozone though. Sorry I don't have any part numbers. Looking at DrDuster's pics, it looks like there might be enough clearance between the frame rail & header that it might work using the hard line. It's worth a try. If nothing else, you could run the heater hoses on top of the frame rail or maybe manipulate the hard line to where it can work for you.
This was one of my earlier iterations.
Yeah, I'm sure no A/C and a carb would make it so much more simple. That darn A/C box takes up so much room.
COTM Editor
Re: 91Z28 LS1 Swap
Love the build progress man. Thanks for everyone posting part numbers on the hoses. I'm sure it will be a big help as I get into mine this fall after the parts collecting is all done.
Re: 91Z28 LS1 Swap
Got some more things done this weekend....finished the trans cooler installation, pcv is hooked up, spark plugs/wires installed, heater hoses/heater valve installed.
I used the stock PCV valve but took the heat sink connection off of it. The PCV valve sits above the passenger side valve cover a little further back than the stock location. The rubber t connection for the PCV system was deteriorated so I replaced all of the hoses and the t. The t connection I used can be found on ebay for about $5 and is some kind of coke machine fitting(Stainless Steel Fitting Barb U-Bend 3/8" Coke part number 21136). That setup will do for now but I will eventually install a catch can.
Re: 91Z28 LS1 Swap
My original plan was to use the thirdgen heater control valve. I hooked it up partially but found that I couldn't position the original hard pipe that runs along the passenger side without it being in the way of everything. The 90* hose that goes to it would have been right against the engine and wiring harness.
With a little more research I found an old post from ghettocruiser where he used a different heater valve, I pretty much copied his setup. It makes for a cleaner installation. I used straight heater hose to the valve then 2 molded hoses with 90* turns to the water pump.
Heater Valve part# 74781
Heater hose 80405CS
Heater hose 80416CS
https://www.thirdgen.org/forums/ltx-...-valve-ls.html
I also found that the 4th gen brake booster hose fits perfectly if you also change out the fitting on the brake booster(3rd gen fitting is too small).
Heater hose 80405CS
Heater hose 80416CS
Car: 91 z28, 92 ZR1
Engine: LS1, LT5
Transmission: T56, ZF
Axle/Gears: 3.73/ 4.10
Re: 91Z28 LS1 Swap
looks good bro, I felt bad when I did mine also it only had 58,000 on it. I am curious about the heater valves. I ran my lines directly to waterpump and the vac. lines to the back of the intake, mine works great. heat and AC. Am I missing something??? So one of the 2 vac. lines go to the heater bypass valve and the other to the small port on the back of the intake???
Re: 91Z28 LS1 Swap
Some people run the coolant lines directly from the water pump to the heater core. Since there is always 100% flow through the heater core the AC won't be as cold..that is what I have read anyway. It gets hot and humid here so I want the AC to work as well as possible.
Re: 91Z28 LS1 Swap
I got the throttle cable installed this weekend. I used a Lokar TC-1000LS1 36" cable. To make it work correctly I used a same/similar method as in these old threads that I found while doing research.
https://www.thirdgen.org/forums/ltx-...ld-swap-2.html
https://www.thirdgen.org/forums/ltx-...z-ls1-t56.html
It took awhile to get the cable out of the stock firewall connector. I cut the stock cable off about 3-4 inches from the firewall connector. Then I used a dremel tool with a cut off wheel to cut the plastic all the way around the cable were it goes into the firewall connector. After doing that I was able to pull the stock cable completely out of the firewall connector. Once that was done I drilled the firewall connector out to the proper size to thread in the new cable. I don't remember what thread it was but I ended up using a 1/4" drill bit(closest I had to the actual size required by the tap) then tapped it the same thread as the Lokar cable. Then I had to completely disassemble the Lokar cable to get it through the stock firewall connector. Checked everything out after installation, works perfect.
I also installed the K&N GTO cold air intake kit(K&N 57-3044). The filter was right up against the driver side inner fender well so I ordered a 45* coupler hose to turn it away from the fender well. I'll post some more pics once I get the new coupler hose.
On to the fuel system now!
Re: 91Z28 LS1 Swap
I added a 45* turn to the GTO cold air kit for better clearance. I also repositioned the charcoal canister slightly.
Re: 91Z28 LS1 Swap
I got the fuel system done this weekend. The stock sending unit was in good shape so I used it along with a racetronix pump and hot wire kit. I used Russell Teflon lined hose, to hopefully avoid any fuel smells or leaks. I can make a diagram with part numbers if anyone is interested in duplicating my setup?
http://www.racetronix.biz/customkiti...c=RFPK-005&eq=
I mounted the corvette filter/regulator in the same location as the stock filter. The fuel line and new power feed for the pump were routed along the driver side subframe connector.
Re: 91Z28 LS1 Swap
I trimmed the lip of metal at the edge of the plastic inner fender liner to give the fuel line a place to slip in behind it. Then cut a hole through the metal at the top to route the hose up to the engine bay.
Re: 91Z28 LS1 Swap
I used a hole saw to cut the last hole into the engine bay and put a grommet in to protect the hose and wiring. I wrapped the hose with a heat shield, probably overkill but I already had it so why not.
I didn't use the fuse that came with the hot wire kit, the length wasn't right plus I broke the plastic cap on it the first time I took it apart. I mounted a 20A breaker down in the area by the charcoal canister and ran the wire over to the alternator to feed the pump.
My original plan was to route the fuel lines the stock route through the trans tunnel but it was too tight of a fit around the headers. I also tried running it up on top of the trans and couldn't get the hose with the fitting on it through. This was more work but a better route though, the hose should be way far away from any heat.
I'll test the pump and maybe fire the car up tomorrow if all goes well.
Re: 91Z28 LS1 Swap
Thanks I've followed your swap too. I got the car fired up for the first time today...my neighbors probably hate me(open headers lol). The good news is that the engine sounds good, no issues there. It seamed hunt a little at idle but that may be due to the open headers?
The bad news is that the trans appears to be no good. I have to rev it to 3500-4000 just to get it to move. I couldn't even get it up the hill back into the garage without a push. I'm confident the converter is seated in correctly. On the very first start up it threw a P0740(torque converter clutch solenoid circuit) code but I didn't take it out of park since I didn't have the driveshaft in yet. I put the drive shaft in reset the code and then started it again. Fluid was slightly low maybe 1/2-3/4 qt low so I topped it off, then put it into gear. I pulled it out of the driveway then back up into the garage. Had to get a push just to get up the little step into the driveway. No codes were thrown that time. Anyone have any ideas? trans rebuild time? I'm surprised the trans has an issue since the fluid looked so clean.
Re: 91Z28 LS1 Swap
Update: Got the trans issue fixed. I did some reading on the codes it was throwing. It was throwing several codes and was in limp home mode. I checked the voltage going to the trans and it was good. Then I figured out that I didn't have the connector for the trans in correctly. It will go in about 75% of the way and feel tight when the connector is 180* from where its supposed to be. I turned the connector around and snapped it into place. Took it for a drive and it shifted through every gear. Now its time to install the hood, front gfx and exhaust.
It seems to surge at idle sometimes after a rev and sometimes wants to die..is this normal for a open header LS1 car? I'm guessing its sucking ambient air into the header tube after a rev and messing with the O2 sensors. That condition seemed to get better as I drove the car more but was still there. This is the first open header fuel injected car I've ever dealt with.
Car: They all sit.
Engine: LS1, LB9, LB9, L98, LT1, LT4, LT4
Transmission: A4, T5, T5, A4, A4, T56, TR6060
Re: 91Z28 LS1 Swap
awesome thread. Once I get my ducks in a row ill be installing my LS1/4L60 into my 90 iroc vert. I used a complete 2001 Trans am for my swap parts. I'll be coming back to this thread when my time comes
Car: 91 Z28
Engine: 6.0L LQ9
Re: 91Z28 LS1 Swap
Re: 91Z28 LS1 Swap
I got the Mufflex cat back system hung today. I went with the 3.5in system with a Magnaflow muffler. Almost seemed like it wouldn't fit at first but once you get it on and made a few adjustments it's perfect. I'm dying to drive the car some more but it might be a couple of weeks before I can get a y-pipe made.
I've searched with inconclusive results on how to finish the AC. Do you have to change the pressure switch for the AC when using the 4th gen compressor? I'm assuming you do since the refrigerant is different and probably a different pressure?
Car: '88 Iroc-Z
Re: 91Z28 LS1 Swap
I used the 3-wire switch from my 4th gen donor car. Simply installed in place of the exiting 2-wire 3rd gen switch.
Re: 91Z28 LS1 Swap
I got the exhaust done last weekend. I bought a flowmaster Y, mandrel bends and some straight pipe and a friend welded it up. I put a V band after the Y so I can remove the whole Y pipe and get it out of the way if needed. Ground clearance is pretty good, very close to what it was with the stock dual cats. I really like the sound of the magnaflow muffler. Its loud enough to be noticable but not obnoxious and no drone while going down the road.
I've driven the car a few times now that I have exhaust on it and I'm impressed with the LS1. It feels like it should run a low 13 or maybe high 12 depending on traction. It really comes alive above 3500rpm, more than I thought it would for a stock engine. The 3200 stall torque converter helps in keeping it in the its power band for sure. Traction is definately a lot more of an issue now than with the L98.
I've got an appointment at a local shop on Tuesday to get it aligned. Then in about 3 weeks I'm going to take it to a local tuner and get it fine tuned.
Car: 91 Z28
Engine: 6.0L LQ9
Re: 91Z28 LS1 Swap
enjoyed the back to back write-ups in camaro performers on you and your dad's cars.
keep up the good work, always have to represent with the white 91 Z's.
Re: 91Z28 LS1 Swap
Thanks...I haven't even seen the newest magazine yet with my car in it. I kinda wish I would have gotten the car in the magazine after the LS1 swap but either way its cool to make it in.
Re: 91Z28 LS1 Swap
Here are some pics that I took during the Camaro Performers photo shoot.
Re: 91Z28 LS1 Swap
And a few more pics. The black 92 is of course my Dad's. It has a 355 TPI w/ cam and Iron Eagle heads, Shorty Headers, Mufflex 3.5in exhaust, T5, 3.73 gears, koni shocks/struts, founders panhard bar & LCA's, BMR strut tower brace, subframe connectors. Hes finishing up the interior now, we just put new door panels in yesterday. He is still waiting to get the seats back to finish it up.
Re: 91Z28 LS1 Swap
I've been driving the car quite a bit. I drove it to work and to a car show last weekend. It was a nice day last Wednesday, a couple of friends at work drove their cars too. Almost like a mini-car show at work(see picture).
I also figured out I have a few bugs to work out. The belt started to make noise. Replaced the belt and it was quiet for awhile then it started making noise again after driving a few times. So I replaced the tensioner, idler pulley, and put a gatorback belt on it. The new tensioner seems to hold the belt tighter so I think that was probably the issue.
Also found the heater valve is leaking a little. I replaced the 4 seasons brand heater valve with an AC Delco one. The equivalent AC Delco part# is 15-5533. The 4 Seasons valve seems very cheaply made, I would advise getting the AC Delco one.
Hopefully I'll get the AC working within the next couple of weeks. I replaced the accumulator and o-rings to get it ready.
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
Re: 91Z28 LS1 Swap
Nice spread in the magazine sweet was reading it yesterday s b d realized that car looks familiar
Re: 91Z28 LS1 Swap
I had the car tuned on a dyno yesterday by Mike Norris. The car has more power now and he got rid of the low idle issue I was having. Ended up with 340HP / 350 ft/lbs torque at the rear wheels. Dyno numbers don't mean a whole lot but I'm happy with the results.
When I had the car up on the dyno lift i could see better and finally found where I have one last exhaust rubbing issue. The 02 sensor on the drivers side header rubs against the trans tunnel slightly. It doesn't make any noise but you can feel the vibration under your feet when driving sometimes. Hopefully I can dent the tunnel without having to take the header off.
Still need to get the AC charged too, I'll try to get that done within the next couple of weeks.
I'm Heading to thirdgenfest today with the car.
Car: 1992 Black Z28 Hardtop
Axle/Gears: 2002 10 bolt w/3:23
Re: 91Z28 LS1 Swap
Good deal, man your Z is a work of art. Very good thread, hope mine goes as well. I'm still in the planning stage doing smaller resto-mods till I can get the engine/trans.
Car: '89 Camaro
Transmission: 4L65/70E
Axle/Gears: 9 Inch, 3.70 gears
Re: 91Z28 LS1 Swap
It was good talking with you at ThirdGen Fest the other day. It was too bad that you left early, both cars ended up with a bunch of trophies.
Re: 91Z28 LS1 Swap
It was good talking to you too. I probably should have stayed but I had a long drive home, I wasn't sure how much longer it was going to last.
Re: 91Z28 LS1 Swap
A couple of quick updates. Got the AC charged a couple of weeks ago and it works great. Its just as cold as the original R12 system. I put a new accumulator on with 8oz of PAG oil added to it and replaced all of the o-rings . I took it to a local shop and they leak checked it and charged it. No issues so far.
I installed a catch can this morning. I noticed the car had some smoke on deceleration on the dyno from intake sucking oil through the pcv valve. My tuner said it was typical with no catch can and no cats.
Took the car to a couple of local cruise-ins last weekend, its been hot and humid...ac is nice!
Re: 91Z28 LS1 Swap
Nice, it's the small touches to a good build that completes the job, makes you proud of your efforts. Great build.
Re: 91Z28 LS1 Swap
I am planning my build with a 4L60E also, how is your shifter cable surviving the header heat? Any issues? I may use mid length Headman's on my build.
Re: 91Z28 LS1 Swap
Clearance is tight between the shifter cable bracket and exhaust but I have no issues with it. I actually trimmed the bracket a little bit for extra clearance. Shifter cables are pretty tough, not prone to melt or anything like that. I considered the hedman mid length headers too but I got a good deal locally on these hawks headers used. I've heard that kooks is coming out with a stainless midlength header too.
Re: 91Z28 LS1 Swap
Great, I was concerned about this. I prefer the Hawks long tubes but was concerned about clearances. Also ground clearance is an issue. I guess if I want long tubes I need to ditch the Spohn TA.
Re: 91Z28 LS1 Swap
The hawks headers do fit well and tuck decent for long tubes. Even with the Sportline springs ground clearance isn't too bad, I've scraped the air dam a couple of times but never the exhaust yet. To me the worst part of the hawks LT headers is the lack of flange on them, they leave it up to you to figure out how to bolt them up to the rest of the exhaust. Not a big deal but adds to the time and expense of getting everything put together especially if you don't have the ability to to weld. I also had to dent the trans tunnel on the drivers side to clear the o2 sensor.
Re: 91Z28 LS1 Swap
I installed a V Max ported throttle body last weekend. The butt dyno says it made a difference, throttle response is better and it seems to make a little more power. Nothing huge but a noticable difference. I'd say it's definately worth the $150. Hopefully I can make it to the track soon and see how it runs. Traction will be an issue, but I think the mph will be decent.
Re: 91Z28 LS1 Swap
This is an absolutely awesome swap, kudos for your attention to detail making it look like that engine was there when it rolled off the assembly line!
Can you elaborate more on what you did for AC? Are you using the 4th gen compressor with everything else from the original car (save for the 3-wire pressure sensor)?
Re: 91Z28 LS1 Swap
Re: 91Z28 LS1 Swap
Update: Finally got a chance to run the car last night at the drag strip. I was hoping for a little better ET but overall I'm happy especially with the mph. Air was good but the track was very slick. They put cones up to make the street cars line up outside the groove making it even more slick since I was on street tires. Lots of fwd cars were dragging water up to the starting line too. I had to roll out half throttle in first and not really get into it until 2nd gear. 275/40/17 Firestone Firehawk tires were struggling to hook.
Right lane on the attached time slip is me. 12.83@109.67 with a 2.07 60'.
Now I need some drag radials and a 12 bolt for some low/mid 12 sec time slips.
Car: 1986 IROC-Z
Engine: LS1-ish
Transmission: T56 stage II
Axle/Gears: S60 4:10's
Re: 91Z28 LS1 Swap
I was looking to get this same exact exhaust you have, but I am nervous of clearance, especially with my S60 rearend. How much clearance do you have to the axle?
Car: 1989 IROC LSX
Engine: Swapped LS6 Forged by LME
Transmission: 4L65E
Re: 91Z28 LS1 Swap
Beautiful build!! I am baffled a little at the thought of you and others just taking the 4th gen A/C switch and screwing it on to the liquid line?? my 89 liquid line and 98 liquid line had different threads. I had a local company splice my A/C line so I could have the correct threads.
Very clean swap!
