862 heads?
Old Dec 23, 2013 | 01:11 AM
turbota82's Avatar
Car: 1989 Formula
Engine: l98
862 heads?
I just found a 5.3 in the local bone yard. It has the 862 heads on it and was just wondering if these are the ones that flow the same as the 243 heads. Please someone let me know ASAP. Thanks guys.
Old Dec 23, 2013 | 07:55 AM
jtaliaferro's Avatar
Re: 862 heads?
In short NO.
Casting Number 706 and 862
Head: 1999+ 4.8L / 5.3 Liter Truck
Material: Aluminimum
Part Number:
12559862
12561706
Combustion Chamber Volume: 61.15cc
Compression Ratio: 9.5:1
Intake Port Volume: 200cc
Exhaust Port Volume: 70cc
Intake Valve Diameter: 1.89 inches
Exhaust Valve Diameter: 1.55 inches
Stock Head Flow Numbers
Chamber 61.15 cc----0.100--0.200--0.300-- 0.400--0.500---0.550---0.600
Intake 200 cc----------63 ---128----179-----210----218----221-----226
Exhaust 70 cc----------54 -- 93 ----121----145-----163----168----174
Casting Number 243
Head: 2001 LS6 5.7 Liter Passenger Car
Part Number:
12564243
Combustion Chamber Volume: 64.45cc
Compression Ratio: 10.5:1
Intake Port Volume: 210cc
Exhaust Port Volume: 75cc
Intake Valve Diameter: 2.00 inches
Chamber 64.45 cc-------0.100---0.200--0.300--0.400---0.500---0.550---0.600
Intake 210 cc------------62------126----184----224-----251----256----257
Exhaust 75 cc------------57------108----143----163-----176----180----183
Old Dec 23, 2013 | 10:07 AM
Pocket's Avatar
Car: 91 Trans Am
Re: 862 heads?
^ There you go, basic 4.8/5.3 heads
799 (243) heads only came on aluminum 5.3's and GEN IV 4.8/5.3's. 243's are exclusive to LS2/6's
If the engine is a decent price, you should still grab the drivetrain regardless of head type
Old Dec 24, 2013 | 12:13 PM
Marc 85Z28's Avatar
Re: 862 heads?
They're found on over a half dozen other engines as well.
Old Dec 25, 2013 | 04:28 PM
25th327RS's Avatar
Car: 92 Ttop Z28
Engine: Cammed 6.0
Axle/Gears: Built 10 bolt-3.90s w/ PBR discs
Re: 862 heads?
I have seen 243s on LS4 engines, and several 2007-up pickups and SUVs with 5.3s
Old Dec 28, 2013 | 10:33 AM
1nasty86's Avatar
Car: 1986 camaro
Engine: ls2
Transmission: FLT stage 6 60e
Axle/Gears: 8.8 with 3.73's
Re: 862 heads?
317's flow the same as a 243/799 head....
Old Dec 28, 2013 | 03:54 PM
25th327RS's Avatar
Car: 92 Ttop Z28
Engine: Cammed 6.0
Re: 862 heads?
But with a larger chamber/less compression.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
