5.3 vortec with T-5
Old Jan 4, 2014 | 11:28 AM
mds5's Avatar
Car: 87 I-ROC
Engine: 350TPI
Transmission: WC 5spd
Axle/Gears: factory 3.27?
5.3 vortec with T-5
I'm swapping a 2001 5.3l vortec into my 87 camaro. I'm currently running a T-5 with a 13in. flywheel, the flex-plate I took off of the 5.3 is 14in. and does not quite fit into the bellhousing. I'm wondering if any of you know if I can just run the 13in. flywheel and the factory starter will for fine or if i need to get a different flywheel and bellhousing.
Old Jan 4, 2014 | 11:44 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Re: 5.3 vortec with T-5
Your 87 flywheel will not work with the 5.3.
Look at the swap threads to see what flywheel and adapters you'll need.
That said, I have never seen anyone mate an LS to a T-5. As you know t-5s are pretty weak as it is, and most people swapping to an LS go with an LS based T-56.
Old Jan 4, 2014 | 10:44 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
You'll need a Lakewood bellhousing, or equivalent, to mate the T5 to the LS and retain the 3rd gen hydraulics. Pocket is doing a T5 to an LS but using the 4th gen hydraulics and a 621 bellhousing
I have the Lakewood and I had to grind the inside of the bell to clearance for the bolts on the rear cover to the LS, top 4 I think.
Old Jan 5, 2014 | 08:56 PM
Pocket's Avatar
Car: 91 Trans Am
While a starter for the smaller flywheel IS available for LSx engines, it is over $800. Get a new bell and use a LS1 clutch
If you're going to bang on it at all, go with a T56
Old Jan 6, 2014 | 08:16 PM
mds5's Avatar
Car: 87 I-ROC
Engine: 350TPI
Thanks!
ZZ3Astro
Aug 13, 2019 12:57 AM
customblackbird
Oct 1, 2015 04:30 PM
monte87cortez
Sep 26, 2015 08:10 PM
Amillionoh7
Sep 11, 2015 11:36 AM
DARKmj16
Sep 9, 2015 04:07 PM
