Stock 2.8L to LSX Swap Best K-member
Old Apr 25, 2014 | 10:06 PM
SavageKayven's Avatar
Car: Pontiac Firebird
Hey everyone I need some help with my project...
I just got a LS1 engine & T56 Transmission for my 89 Firebird.
I need a new K-Member for the engine to sit on. But Im kind of on a $$$ budget prolly 700$ max, What brand and which set up should I get? Even if its 1000$ please throw your opinion out there !
Old Apr 25, 2014 | 10:48 PM
bttrflybird's Avatar
Car: 89' Bandit 2 #104 of 500
Engine: LS1 5.7L
Transmission: 4L60e
Axle/Gears: 3.23 posi
Re: Stock 2.8L to LSX Swap Best K-member
I got mine from AJE i got the drag style kmember and arms for $780...great piece!!!!
Attached Thumbnails Stock 2.8L to LSX Swap Best K-member-20140308_172221.jpg   Stock 2.8L to LSX Swap Best K-member-img_0053.jpg
Old Apr 26, 2014 | 09:44 AM
Pocket's Avatar
Car: 91 Trans Am
Stock works great. Notch it for Ac if using the low mount compressor. Oil pan notch is optional
Do NOT use the spohn k-member
Old Apr 27, 2014 | 01:26 PM
okay nice! So all you needed was the k member and the a arms? and it was ready to go?
Old Apr 27, 2014 | 03:42 PM
rickyzZ28's Avatar
Car: 1990 RS
Axle/Gears: 3.73 9 bolt
I am using a BMR unit with their A-Arms and have had no issues with it, other than for one reason or another my solid motor mounts would not fit so I had to run the stock rubber ones. It could have been a problem with the mounts or the K-member though. I am running Spohns QA1 coil over kit as well.
Old Apr 27, 2014 | 10:02 PM
camaro91's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Axle/Gears: strange s60 4th gen width - 3.73
what's up with the Spohn piece?
Old Apr 28, 2014 | 04:49 AM
how much did your set go for?
Old Apr 28, 2014 | 04:50 AM
I saw nothing but bad reviews on spohn
Old Apr 28, 2014 | 08:28 AM
rickyzZ28's Avatar
Car: 1990 RS
I bought the K-member on here used for $350 and the A-Arms were $379, but I did use the A-arm without the factory spring mount. A new K-member would be $529 from them and coil spring A-arms are $500.
Old Apr 28, 2014 | 06:01 PM
3rdGenLs's Avatar
Car: 1988 Chevy Camaro
Axle/Gears: 10 Bolt 28 spline, 3.73
PA racing, for $799.95 you get k-member, coil over kit with springs, and lower A- arms
Old Apr 29, 2014 | 12:07 AM
92BLKL98's Avatar
Car: 1992 Black Z28 Hardtop
Axle/Gears: 2002 10 bolt w/3:23
Pocket, I'm getting ready to do mine in the next few months, spoke to the folks at Spohn what is wrong with their product?
Old Apr 29, 2014 | 06:46 AM
Pocket's Avatar
Car: 91 Trans Am
Do a search on my name and the k-member for a pic thread with my gripes
Old Apr 29, 2014 | 08:24 PM
Okay I think I'm going with the PA Racing K-Member since they got a decent price for their parts I just reviewed up on them. Thanks. You didnt have any minor problems with any alignment or lining up with bolt holes?
Old Apr 30, 2014 | 10:43 AM
Pocket's Avatar
Car: 91 Trans Am
Nothing a pry bar or ratchet strap couldn't solve
Old Apr 30, 2014 | 11:00 AM
robguitargod1's Avatar
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
Why not stay stock? Here's some pros/cons
Stock:
Pro
- It's free
- Protects the engine better
- Can be notched for AC
- Can use other A-arms in the future
- New bushing/ball joints in stock A-arms works great
- Stock brake lines connect to it
Con
- Heavier than aftermarket K-members
- You'll have to clean it/paint it. (well, you don't HAVE to)
- You'll have to pay someone to notch it if you don't own a welder
Old Apr 30, 2014 | 07:57 PM
hmmmm your right pocket ill keep those tools in mind no doubt
Old Apr 30, 2014 | 07:59 PM
Stock:
Pro
- It's free
Con
trying to dump everything thats old and make everything new!
I dont trust my front end much since it got beat up a few times this
year smfh.. but your pros and cons are on point ill most def keep it in
consideration if something happens along the road.
Old May 1, 2014 | 06:32 AM
Pocket's Avatar
Car: 91 Trans Am
The k-member is not a wear item. If you didn't have a hard collision wrecking the front suspension, then I wouldn't worry about it
If you hit stuff frequently, I'd stay stock
Old May 1, 2014 | 09:57 PM
Gregs_GSXR's Avatar
Car: '91 Camaro
Engine: LSx
Transmission: 4l60e
Axle/Gears: posi
I would agree, I just finished my swap, I stayed with the factory k member, clean it up and painted it. Money could be used else where and you could always upgrade the k member later.
Old May 2, 2014 | 02:54 PM
92BLKL98's Avatar
After reading this thread I have changed plans and will keep the factory K-member. Just notch it for A/C and paint it. Thanks guys
Old May 2, 2014 | 03:40 PM
Well pocket I guess im staying stock then ! What is all I will need for the LsX to fit on that K member? Just the mounts?
Old May 2, 2014 | 03:41 PM
Thanks alot! Staying stock now also !
Old May 2, 2014 | 03:42 PM
Anybody got some guides to "notching " the K member for the AC,
or the price somebody would do it for ?
Old May 2, 2014 | 05:48 PM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
Make it look like this and it will work, the attached pics are of my k-member. Also be sure to check the A-Arm clearance before putting the k-member back in. You may have to grind a little off the a-arm to get full travel or make the notch less deep.
Prices would vary widely I'm sure, I would expect some where between $100-200 depending on who you take it to.
Hawks sells a notch plate kit that would take the guess work out.
http://www.hawksthirdgenparts.com/pr...Plate-Kit.html
Attached Thumbnails Stock 2.8L to LSX Swap Best K-member-k1.jpg   Stock 2.8L to LSX Swap Best K-member-k2.jpg
Old May 3, 2014 | 09:56 PM
Car: '91 LS6/T56/9"
Engine: LS6
Here's the Hawks notch
Old May 21, 2014 | 04:46 PM
Thanks for the info ! Needed that most def! But what motor mounts do I get for the stock k member ? Do I need adapters or anything like that ?
Old May 21, 2014 | 04:48 PM
Hey pocket what motor mounts can I put on this stock k-memer?
Old May 22, 2014 | 07:02 AM
WTR388's Avatar
Car: 87 Trans Am
These are what I'm using... They're in the mail apparently, so I haven't used em yet.
http://www.hawksthirdgenparts.com/pr...s%2C-Pair.html
Old May 25, 2014 | 11:34 AM
Pocket's Avatar
Car: 91 Trans Am
Two choices for stock k-members:
Those swap mounts linked use 4th gen block mounts. The stand bolt to the k-member in the v6 mount location
Alternatively, the stock v8 mounts can be retained and an adapter plate used between the SBC clamshell and LSx block. Standard and 1" setback are common, but the setback version are required to reuse the stock driveshaft. These do not clear the low mount Ac compressor
Old May 28, 2014 | 12:59 AM
Even if I notch the stock kmember it wouldn't be clear ?
Old May 28, 2014 | 06:45 AM
Pocket's Avatar
Car: 91 Trans Am
The low mount Ac compressor occupies the same space as the pass motor mount when using SBC mounts and an adapter plate. Not a whole lot you can do about that short of using a different mount or moving the Ac up top
1984HO
Mar 19, 2021 11:59 AM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
sreZ28
Aug 14, 2015 07:48 PM
gwade12
Aug 8, 2015 08:17 AM
NBrehm
Aug 5, 2015 07:57 PM
