Trans cooling lines
Car: 1988 Camaro
Engine: 5.3L LM7
Axle/Gears: 3.73 1LE '90 Disc
Trans cooling lines
Hey guys,
Swapping in a 5.3 and 4l60e and bought a set of fourth gen trans lines and curious if any of you are using them? I am going to hook them up to an ls1 radiator / external cooler. Need routing advice or any photos of them on a third or fourth gen as a reference. The only complication I'd that I am using an aje racing kmember. Not sure if it will be in the way.
Thanks for any input.
Bryan
Bryan
Car: 1988 Camaro
Engine: 5.3L LM7
Re: Trans cooling lines
Do the third gen lines snap in at the trans? Will they have to be adapted at least on the feed line going into the ls1 radiator? Unfortunately I have some fourth gen ones already that I got from hawks. They said they normally use those and cut the ends off and hook to the external cooler only... I let my original third gen ones go already.
Car: 1988 Camaro
Engine: 5.3L LM7
Yes agreed. I might get a tubing bender and see if I can get them closer so there will be a minimum of it and at least hide the ugly. Haha.
Car: 1988 Camaro
Engine: 5.3L LM7
Yeah that's an idea, how about making the ends that go on the trans side, where they can snap on? How do you make those, with a flaring tool?
Car: 1988 Camaro
Engine: 5.3L LM7
I know this is probably simple stuff for ya'll sorry its my first time doing trans lines.
The factory style quick connects will be hard to duplicate, but generic nuts will not. The quick connect fittings unscrew from the trans and it take the same thread as most older trans
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
