58x-24x crank sensor wiring ????
Old Jul 27, 2014 | 11:34 PM
Slush92RS's Avatar
Car: 92RS
Engine: LS 402 inwork
Transmission: TH350
Axle/Gears: 10 bolt,3:73's
Is there a difference in they way they are wired up. I cant find a pigtail anywhere to swap over my wiring for my 58X crank sensor. Does anybody have a lead on where I can get a connector only or even a pigtail to splice into my harness. Rookie me wasn't aware of connector differences when I got my Holley HP EFI setup, I went with the LS1 version because my motor is a mix of LS variants....I already have the cam sensor adapter/extension. I have sourced a pigtail for my LS9 Map sensor.
Old Jul 27, 2014 | 11:45 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: 58x-24x crank sensor wiring ????
Call Holley tech line.
Old Jul 30, 2014 | 08:02 PM
Slush92RS's Avatar
Car: 92RS
Transmission: TH350
Nevermind, after looking at the wiring diagrams for both harnesses I will have to swap to the LS2 version harness, the logic is different between them.
Caspar
Jun 19, 2016 11:19 PM
Bert87
Aug 23, 2015 03:50 PM
Winchester1094
Aug 18, 2015 10:23 AM
