350 tpi to ls2 wiring harness
Old Oct 26, 2014 | 08:39 PM
Brianbajnuth's Avatar
Car: 87 GTA Trans Am
Engine: 5.7 350 TPI
Transmission: TCI transmission
Axle/Gears: 4th gen rear end. With 3.83
Does anyone make these harnesses? Can I make it myself?
I'm currently thinking about swapping my 350 tpi for a ls2 from a gto.
Is it a good idea?
The only thing I'm worrying about is the wiring! Can some one clear this up? Thank you
Old Oct 28, 2014 | 10:42 AM
rhoop24's Avatar
Car: 93 Z28
Transmission: 97 4L60-E
Re: 350 tpi to ls2 wiring harness
Save yourself a headache and let the professionals over at Speartech make it for you. All you would have to do is plug it in. I think their reworks might be on hold due to high volume of stand alone harness's though. Not sure if you have the old harness or not.
Old Oct 29, 2014 | 03:02 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
By any chance did you read the LS1 sticky in the top section of this forum?
Yes, it says "LS1", but it applies to the other LS variants.
If you had read the sticky, you would have seen this link:
https://www.thirdgen.org/forums/ltx-...p-3rd-gen.html
Old Nov 16, 2014 | 11:07 PM
alex722607's Avatar
Car: 1988 Pontiac Transam GTA Notchback
Engine: 2003 Chevy 5.3 Vortec (325 cu)
What I am doing is simple, everything from the firewall forward is going to be 4th gen wiring - meaning pcm in the 4th gen stock location and fuse boxes. Everything firewall back is third gen just with a little beefed up wiring. Then again I like playing with wires. Pocket's thread is really invaluable to do the swap. After reading his threads I was able to make myself a diagram for the wiring and sort out what I want/don't need.
Old Nov 23, 2014 | 09:31 AM
robbe_iroc's Avatar
Car: 1989 Iroc
Engine: LS2
Transmission: GTO T-56
Axle/Gears: 4:th gen Auburn with 3:73
I have done that very same swap. I used a J1 harness from Speartech, and that´s about everything you will need to get the LS2 running. Send you computer to someone who can delete some codes that you won't need, and turn off the VATS. The car will be a million times more fun.
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
armybyrd
Dec 5, 2015 09:22 AM
Reddeath210
Oct 6, 2015 08:20 AM
wruiz
Aug 13, 2015 09:07 PM
