Fuel question
Old Nov 25, 2014 | 08:21 PM
alex722607's Avatar
Car: 1988 Pontiac Transam GTA Notchback
Engine: 2003 Chevy 5.3 Vortec (325 cu)
Fuel question
Well after looking and asking and getting no results, I am going to pose this question in its own thread.
I am building an LS motor for my car and I need to know what to do with the fuel system. i have a 4th gen tank and an LS1 firebird fuel filter. I drew up a diagram, but it seems to me that putting a T after the fuel filter and having a return there would just cause the fuel to pressurize both lines and simply drain back into the tank, thus not pressurizing the feed line. Attached is what I cam up with, tell me what to do TGO!
File Type: pdf
Old Nov 25, 2014 | 09:26 PM
Bomber's Avatar
Car: 92 Camaro RS
Engine: turbo 5.3
Transmission: th400 with 3500 stall
Re: Fuel question
Why don't you get a corvette filter? And that wouldn't work and if it did you won't get enough fuel to the rails
Old Nov 25, 2014 | 09:29 PM
Mirror Image's Avatar
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
Re: Fuel question
Im using a fuel pressure regulator for my return
Old Nov 25, 2014 | 09:33 PM
alex722607's Avatar
Re: Fuel question
Already had an LS1 f-body filter and I am trying to utilize that.
Is the pressure regulator already on the in tank pump setup for the ls1 return? So what I am asking is the place where the return is on the in tank pump is that regulated or is the feed regulated?
Old Nov 25, 2014 | 09:41 PM
Bomber's Avatar
Car: 92 Camaro RS
Engine: turbo 5.3
Re: Fuel question
I have my return from my regulator after the rails , the car seems to like that more. you can use a regulator but you'll be spending more money just to use the f body filter
Old Nov 25, 2014 | 10:09 PM
alex722607's Avatar
Re: Fuel question
? what do you mean
Old Nov 25, 2014 | 11:05 PM
Bomber's Avatar
Car: 92 Camaro RS
Engine: turbo 5.3
Re: Fuel question
I have my pumps go to the feed line to the passenger fuel rail and then to the driver side then to the regulator and back to the tank, but i do have aftermarket fuel rails
Old Nov 26, 2014 | 09:47 PM
Lonnie P's Avatar
Car: 91 Formula
Engine: 2012 LS9
Transmission: 4L80E
Axle/Gears: Strange 60 3.54:1
Re: Fuel question
Your setup will work as long as you have retained the factory regulator in the fuel module.
You picture shows the return going to the center which is the vent....
You need to plumb the return to the port closest to the passenger side of the car.
This is the return port.
Old Nov 26, 2014 | 09:57 PM
alex722607's Avatar
Re: Fuel question
Thank you very much!!
I haven't removed the regulator, oh and I should have payed attention to which ports I drew the line to
Now i can order my fittings! Thank you again
Frozer!!!
Jan 19, 2024 04:55 PM
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
fasteddi
Sep 2, 2015 10:29 AM
redmaroz
Aug 16, 2015 11:40 PM
