harness routing
Old Feb 8, 2015 | 03:41 PM
RS/SS 4.8's Avatar
Car: 1991 Camaro RS
Engine: 5.3 V8 LS
harness routing
Hey i know there was a thread about routing a lsx harness under the a/c box but i cant seem to find it. Anybody know which one it was or have pics of how to do it. Thanks.
Old Feb 8, 2015 | 06:01 PM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
Re: harness routing
We're you going the stock rout through the fender or did you want to drill a hole? Several threads/builds have showed it. But it's pretty easy either way. I just drilled a hole under the ac box
Old Feb 8, 2015 | 07:56 PM
RS/SS 4.8's Avatar
Car: 1991 Camaro RS
Engine: 5.3 V8 LS
Re: harness routing
I ordered a harness from pocket for under the a/c i pulled the a/c box and it looks pretty tight down there. Just wanted to see what working for you guys.
Old Feb 8, 2015 | 09:14 PM
plum92_camaro's Avatar
Car: 92 Camaro RS
Axle/Gears: 10bolt w3.42 Torsen
Re: harness routing
seen the same thread, i remember it said to make sure you leave some space between the hole and frame rail or water can run into the car.
Old Feb 9, 2015 | 05:02 AM
cypris09's Avatar
Car: 87 Gta
Engine: 5.3
Transmission: 4l60e
Re: harness routing
Right, I want to say I'm roughly an inch or so up off the rail. I no longer have a heater box so I just used one of the holes and opened it up to fit the harness. Right now I need to find the rubber grommet that fits the hole.
Old Feb 9, 2015 | 08:32 AM
rickyzZ28's Avatar
Car: 1990 RS
Axle/Gears: 3.73 9 bolt
Re: harness routing
I lengthened all of my wires and ran it under the AC/blower box and through the fender like it was from the factory. You can not see the big bundle of wire and I think it really cleaned up that part of the wiring. I did wrap the harness where it goes near the header under the box just for safe measure but have had no issues with it.
Old Feb 9, 2015 | 12:18 PM
RS/SS 4.8's Avatar
Car: 1991 Camaro RS
Engine: 5.3 V8 LS
Re: harness routing
Yea now that i think about it i should have ordered it for stock style mount. Anybody have any pics or their under a/c mount?
Old Feb 10, 2015 | 12:01 PM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Re: harness routing
I made an oval hole, and trimmed it out with rubber hose split down the middle lengthwise. I did it this way on two different cars and it worked good. If I do a third car, I will be building a completely new harness and probably go through the fender opening. Which I did use for some of the harness...HVAC stuff.
I had to notch the passenger hush panel to tidy things up.
Here's how it looks standing back a bit.
The harness is a LITTLE close to the header. Thats my only beef. I havent had any wires melt, but some of the split loom got a little toasty.
Justin
Old Feb 10, 2015 | 08:35 PM
RS/SS 4.8's Avatar
Car: 1991 Camaro RS
Engine: 5.3 V8 LS
Re: harness routing
Thats exactly where i was looking to route mine. I have no problem triming some stuff as i bought the car as a v6 RS roller. Thanks cruiser.
Old Feb 12, 2015 | 01:12 AM
dprest68's Avatar
Car: 1989 Pontiac Trans Am GTA
Engine: cammed LS1
Transmission: Monster SS 4L65E
Axle/Gears: 9 bolt posi w/ 3.70 gears
Re: harness routing
I did mine a little different than Ghettocruiser did. I did mine under the A/C box and there's no need to cut interior panels where I did mine. There's more information on page 6 of my swap thread. I also found a nice 2" grommet to finish it off nicely. All of the information is on my thread. See the link below if you are interested.
Old Feb 13, 2015 | 07:52 AM
RS/SS 4.8's Avatar
Car: 1991 Camaro RS
Engine: 5.3 V8 LS
Re: harness routing
Thanks dprest68. I was looking at that spot and may end up going with it to get away from the motor and the exhaust manifold.
Old Feb 13, 2015 | 11:40 AM
Car: 86 Trans AM
Re: harness routing
I looked into doing it where dprest68 did. In the end, I couldnt fit the harness comfortably through there, and would also have had to extend it quite a bit. I used the stock LS1 harness.
My PCM is mounted in the exact spot where the factory ECM was.
The only reason I had to cut anything inside, was the way I taped my harness up. Had I checked the fit of things before taping, I would have done it differently. I only had to notch the hush panel a little. 1" x 1-1/2" maybe? It was the end of the build and I wasnt in the mood to mess with it anymore haha.
Having done this to two cars, on the off chance there is a third, I would make some changes. 1)Ide strongly consider a harness from Pocket, lengthened if available. 2) I would def do a round hole vs oval, and get a nice Seal It grommet or something.
All options will work well though!
J.
Old Feb 16, 2015 | 07:32 PM
Pocket's Avatar
Car: 91 Trans Am
Re: harness routing
Better late than never. Mine is just a little higher than ghettocruiser's. 2" round hole, insulated with 3/8 fuel line. Basically anywhere in the vicinity will be fine
Old Feb 19, 2015 | 12:48 PM
RS/SS 4.8's Avatar
Car: 1991 Camaro RS
Engine: 5.3 V8 LS
Re: harness routing
Thanks pocket. Got your harness in and everything was labeled and easy to hook up. No regrets lol, i havent been able to get the hole cut but i basically marked it where yours is. Thanks
gixxer92
Apr 12, 2022 12:09 AM
8889gtaformula
Exterior Parts Wanted
Nov 5, 2015 04:17 AM
crystal383
Interior Parts Wanted
Sep 22, 2015 01:20 PM
Camaroguy2
Sep 22, 2015 08:22 AM
gta892000
Sep 16, 2015 12:37 AM
