Who has the cleanest, most factory looking LS swap?
Old Mar 2, 2015 | 12:26 PM
Dialed_In's Avatar
Car: '88 IROC-Z medium orange metallic
Like the title says, I'm looking for some of the cleanest LS swaps out there. I'm toying with the idea of going LS on a restoration project I've got but it needs to look like it came from the factory and I need ideas.
Old Mar 3, 2015 | 07:34 AM
skirocz28's Avatar
Re: Who has the cleanest, most factory looking LS swap?
That is my goal.
https://www.thirdgen.org/forums/memb...o-z28-1le.html
Old Mar 3, 2015 | 03:16 PM
Pocket's Avatar
Car: 91 Trans Am
Use a GTO K&N intake, all black couplers, stock fuel rail unpainted and no braided SS stuff. It can look VERY stock
Old Mar 3, 2015 | 03:18 PM
Pocket's Avatar
Car: 91 Trans Am
https://www.thirdgen.org/forums/ltx-...-lsx-swap.html
More inspiration
Old Mar 3, 2015 | 03:21 PM
Dialed_In's Avatar
Now THAT'S what's up! Thanks for posting. Exactly what I'm looking for except I'll be running A/C. Did you use the factory guages? Did you do your own wiring or buy a harness?
Old Mar 3, 2015 | 03:38 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Yeah, without the stainless, blue and red that is pretty close to stock.
Uhh, yeah I think Pocket made his own harness......
Old Mar 3, 2015 | 04:41 PM
Pocket's Avatar
Car: 91 Trans Am
AC is pretty simple. Low mount uses a 4th gen AC hose with the ends cut off and generic ends crimped on to fit the 3rd gen condenser/drier. High mounts often use a R4 compressor which came stock on 3rd gens, so change nothing. Nothing looks more stock than... stock
I built that harness along with a little over 200 more
Old Mar 3, 2015 | 04:59 PM
Zach/90\irocZ's Avatar
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
Utilizing stock dual snorkel cold air intake
Optional things are
And using high mount alternator
With stock high mount AC conpressor
With those 3 things would be the ultimate stock looking swap any CAI setup and stock f body accessories would be a dead give away of a swap to me being a thirdgen lover but that's just me just depends on how stock looking you want
But pocket picture is a good stock looking swap along with some in thread posted above
But here some pics with stock intake with high mount ac compressor and alternator would be icing on the cake for a true stock look that will have people look twice
Old Mar 3, 2015 | 10:17 PM
dprest68's Avatar
Car: 1989 Pontiac Trans Am GTA
Engine: cammed LS1
Transmission: Monster SS 4L65E
Axle/Gears: 9 bolt posi w/ 3.70 gears
Here's mine
It's definitely not the cleanest, but that was my goal during my swap was to keep it relatively stock looking. The ram air box kind of gives it away though. Oh, and I retained the 3rd gen A/C like Pocket was talking about.
Old Mar 4, 2015 | 07:43 PM
khulsebus's Avatar
Car: '89 Camaro
Transmission: 4L65/70E
Axle/Gears: 9 Inch, 3.70 gears
JBenge
https://www.thirdgen.org/forums/ltx-...-ls1-swap.html
Old Mar 4, 2015 | 08:12 PM
PAFORM350's Avatar
Car: 1992 Formula 350
Engine: 5.7 L98
Originally Posted by dprest68
Here's mine
That's nice!
Old Mar 4, 2015 | 08:38 PM
Alice89's Avatar
Hey dprest68, How did you get your fuel rail covers to fit with the drive by cable bracket/throttle-body?
After switching to the drive by cable set up, the new bracket interferes with my passenger side ls6 fuel rail cover.
Did you just have to dremel out a small chunk at the top front corner of the cover or what?
Nice set up btw, Looks awesome!
Old Mar 4, 2015 | 09:51 PM
dprest68's Avatar
Engine: cammed LS1
Originally Posted by PAFORM350
That's nice!
Thanks!
If I remember correctly, I bought these covers already cut out for that bracket
I would probably cut it out like you said with a dremel.
Thanks for the compliment
Old Mar 5, 2015 | 01:03 PM
rickyzZ28's Avatar
Car: 1990 RS
Axle/Gears: 3.73 9 bolt
Here is mine: Still needs a little cleanup but I am happy with it overall:
Old Mar 13, 2015 | 09:43 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Someone at ThirdGen Fest 2014 last year.
Was a white Iroc or 91-92 Z, was a damned fine clean looking swap.
Old Mar 13, 2015 | 09:58 PM
khulsebus's Avatar
Car: '89 Camaro
That would be JBenge, the same car I posted about.
Ikes 91Z
Dec 9, 2015 03:49 PM
lt1z350
Sep 14, 2015 10:07 AM
eddie jr
Aug 25, 2015 06:52 PM
fonzie85
Aug 13, 2015 11:50 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
