Finally: Holley to produce LT and True Dual System
Old Oct 25, 2020 | 05:38 AM
  #301
toddoky's Avatar
Re: Finally: Holley to produce LT and True Dual System
Originally Posted by 86iroc504
" The Hooker engine brackets and crossmember work in tandem to place the LS crankshaft and transmission centerline axis in the same location as the stock SB engine and transmission was set up with."
Ok, so my ls swap 4.8/4l60e uses setback plates and originally 350 motor mounts that places the engine/transmission in the factory location to where I am using the factory drive shaft & torque arm mount location. Is there a good chance that this crossmember will fit?
Unfortunately not. The engine/transmission mating plane is moved forward slightly in the Hooker Blackheart system to provide the best overall component fitment in the car. Because your engine is mounted with the engine/transmission in the stock position, the transmission will be located further rearward than what the Hooker Blackheart crossmember is designed to accommodate in a bolt-in manner.
Old Oct 25, 2020 | 01:21 PM
  #302
3.1EyeCandy's Avatar
Car: 1987 GTA
Transmission: 4L60e
Just gotta say it's awesome that you still monitor this board toddoky. Your willingness to explain things be a technical resource for this system is one of the big reasons I went all in and bought it, planning to replace my "classic" LS swap components. Just wanted to say thanks.
Old Oct 25, 2020 | 03:32 PM
  #303
skinny z's Avatar
Are you able say how much further forward it is?
Old Oct 25, 2020 | 03:55 PM
  #304
toddoky's Avatar
I’m glad to hear you find value in my efforts. I’m spread a bit thin these days, but I do my best to support all the swap systems I’ve developed.
Old Oct 25, 2020 | 03:58 PM
  #305
toddoky's Avatar
5/8”-3/4”, which is the same distance GM moved the mating plane forward in 4th-Gen F-bodies when they started installing the LS1 in them.
Old Oct 25, 2020 | 05:09 PM
  #306
86iroc504's Avatar
Car: 86 Camaro
Engine: '03 4.8 vortec
Transmission: 4l60e
Ok, thanks. That's good to know
Old Oct 25, 2020 | 05:55 PM
  #307
skinny z's Avatar
I've got the Hooker 71222005HKR crossmember for my Gen 1 SBC, 4L60 combination. While not a direct fit due to the oddball transmission I ended up with (a 4L60 but with a Caprice extension housing which places the rear transmission mount on the extension rather than the trans case) it looks close enough in dimension to the TH400 (IIRC) and should work with either one of Hooker's adaptors or something of my own design. Yet to be determined. But IMO, it's far better than something I might build entirely from scratch.
What is does offer though is excellent clearance for the exhaust. And that's what I'm after. Possibly incorporating the full BlackHeart duals. Again, there'll be some modification needed as I'm outside the design envelope. But I estimate it'll be really close.
Old Mar 17, 2026 | 01:49 AM
  #308
Pavell's Avatar
Any way we can get this system in 2026 ? Any used ones for sale ?
mhatfield 14
Aug 7, 2015 09:03 AM
toxik IROC
May 7, 2006 12:39 AM
84z28350
Feb 23, 2006 09:42 PM
89formula#1
Dec 15, 2005 09:22 AM
Mubie
Apr 24, 2003 01:58 PM
