A/C compressor rubbing Pitman arm
Old Oct 2, 2015 | 05:01 PM
alex722607's Avatar
Car: 1988 Pontiac Transam GTA Notchback
Engine: 2003 Chevy 5.3 Vortec (325 cu)
I have a question - has this happened to anyone before. After recently installing factory 4th gen a/c on my LS1 swapped 3rd gen, it seems that the A/C compressor is rubbing on the pitman arm. What can I do to rectify this?
I am trying to avoid getting a relocation kit especially since I have the stock brackets (and all the trouble I went through to obtain them).
So Suggestions??? Help
Old Oct 2, 2015 | 06:45 PM
Black18Ice's Avatar
Re: A/C compressor rubbing Pitman arm
Make sure the passenger side support on the pitman arm is all the way down as its adjustable. If it is, then grind away at the compressor where the bolts attach. That's what I had to do. It didn't take much and there is still plenty of support left for the bolt.
Old Oct 2, 2015 | 07:10 PM
alex722607's Avatar
HMM, didn't know it was adjustable. Thanks so much. My main concern is not where the compressor attaches, but rather the compressor pulley is the part that is rubbing. So much so that I cant run the compressor safely becuase when the wheels turn left to right ..it hits
Old Oct 2, 2015 | 07:13 PM
Black18Ice's Avatar
Hmm. Mine sat back to far to hit the pulley.
Old Oct 2, 2015 | 07:17 PM
alex722607's Avatar
Im going to try to see what adjustment I can make hopefully that should clear it up. There is a strange creaking and Im not sure if it has anything to do with the compressor hitting the arm.
Old Oct 2, 2015 | 07:56 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Make sure you don't have the steering arm mounted upside down.
Also, what engine mounts did you use?
armybyrd
Sep 28, 2023 12:16 AM
xbazzarex
Dec 1, 2015 05:25 PM
86z89iroc
Oct 5, 2015 01:04 PM
gta892000
Sep 16, 2015 12:40 AM
rudolphschenker
Sep 4, 2015 02:41 AM
