91 Camaro
Old Oct 8, 2015 | 08:24 PM
1986chevycamaro's Avatar
Car: 92camaro,86 camaro
Engine: 355
91 Camaro
are any of this boxes needed for the ls1/4l60e with no heat and no a/c
Old Nov 7, 2015 | 02:03 PM
Pocket's Avatar
Car: 91 Trans Am
Re: 91 Camaro
Not to all 4
Lower left creame is the buffer box. Unplug and jump pins C&F. Discard the box
Black box behind it is VATS. The only part remaining after the conversion will be the starter enable relay. Its located behind your drivers kick panel. Connect the two 12ga wires and its bypassed
Big silver box is the old ECM. Obviously getting replaced by the LS1 PCM
Far right black box is for the old vacuum cruise box. Its not compatible with the LS1 PCM whether or not you want to keep cruise, so remove it
RaverRacerX
Nov 7, 2015 02:25 PM
91L98Z28
Oct 28, 2015 11:42 AM
Bruce Compton
Oct 20, 2015 10:36 PM
Josh Sharp
Oct 8, 2015 01:12 PM
alex722607
Oct 2, 2015 07:56 PM
