oil pan question
oil pan question
Before anyone says anything i have used the search engine countless time and read the ls swap post even more. I have an lq9 that i need a lower profile oil pan and ive read that you can use the fbody oil pan but which year? Or are they the same?
Transmission: 4L80E/4L80E
Yes, 4th gen f-body LS pan, 1998-2002.
Holley also makes a pan that fits fine. Most don't consider it because it is typically more expensive than a used f-body pan.
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
Re: oil pan question
Cheapest option is to modify the truck pan. Mine turned out fine. Actually, the cheapest option is to fab your own from mild steel, I did it, but for my 4WD S-10, haven't test-fitted it in my 'maro yet.
That assumes you have access to the proper equipment, like cutting and Al welding.
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
I did a brand new fbody oil pan, gasket, Windage tray, pickup and all bolts for less than $275. All brand new from stores like summit which price matched a GM performance parts site.
Car: '89 Firebird
Engine: 7.0L
I also bought a new F-body complete oil pan. FYI - the new production parts use an LS3 oil filter, not LS1.
Not necessarily the most budget minded but hey.... it's done and it fits. When I think of having fun working on my car the last thing that comes to mind is making an oil pan.
customblackbird
LSX and LTX Parts
Apr 29, 2016 11:25 PM
Stevolwevol
Nov 5, 2015 01:37 PM
