E-rod installed & Passed
Old Dec 16, 2024 | 12:04 PM
  #151
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: E-rod installed & Passed
The rear a arm mount was in the way of the exhaust manifold outlet. In post 107 or so you can see where I trimmed the mounts. This was possible only because I already had tubular a arms.
The cats still need repositioning after the mounts are trimmed. The secondary ones are the more difficult ones if you go with the auto trans, but the manual should provide plenty of room for both. All four cats need re-adjusting to clear.
I've heard that some e rod kits come with vette manifolds. Mine were camaro manifolds, I believe. Either way I think the manifolds will need modifications. Im hesitant to mention online what I had to do to make mine fit, but they are tweaked a bit. I think it's kinda visible though in those pics posted.
Any mod to the kit is an automatic fail. Thankfully, the ref didn't catch it
Old Dec 16, 2024 | 03:10 PM
  #152
Fred SS's Avatar
Car: 87 Monte Carlo SS
Engine: 89 350TPI Transplant
Transmission: 2004r
Malaka, i noticed in your inspection report there is a line item "Inspection Reason: High Emitter Profile". Does that mean that California pays closer attention to performance cars?
Congratulations on passing the test.
Fred
Old Dec 17, 2024 | 06:40 PM
  #153
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Speaking for myself, thats typical for older cars in Ca, im guessing. Ive seen that same reason on my smog inspections. Prior to and even after the eng change, ive also noticed "change of ownership" on other smog certs.
Old Dec 19, 2024 | 12:08 PM
  #154
KRACKER JACK's Avatar
Car: CAMARO RS
Engine: 3.1 V6,5.0 tpi
Transmission: AUTOMATIC, t5
Axle/Gears: one tire fire ,posi disc
Do you think running a tubular k member would help with cat clearance?
Old Dec 19, 2024 | 09:23 PM
  #155
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Not much, if any. To me the k- member isn't really an issue with the primary cat. Its the firewall. The a-arm rear mount on the k member is the issue with the exh manifold outlets. Once you resolve the mounts/manifolds interference and can bolt up the cat assembly, the primary cat will contact the firewall. So it needs to be adjusted, once that's sorted. Then the secondary cat becomes your next issue to resolve.
Once i got the a-arm mount/manifold sorted. I cut the front weld on the primary cat without cutting into the exh pipe. This let me pivot/rotate/change the angle on the cat to avoid contacting the firewall. From there i worked my way down. Cutting away the welds w/out cutting into the exh pipes. Rearranging the pipes/cats to avoid contact with whatever was in the way. Every weld on both cats had to be cut so i could change the cats and/or pipes configuration.
You going manual or auto?
Old Dec 20, 2024 | 09:28 AM
  #156
Car: CAMARO RS
I bought the lsa used with a 4l80e automatic, the car it's going in is an auto. I'm probably going to try and use the 4l80.
Old Dec 20, 2024 | 11:54 AM
  #157
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Might be a tighter squeeze with 4L80e. It's bigger than the 4L65e isn't it? Basically a turbo 400 with OD, right?
Old Dec 22, 2024 | 11:12 AM
  #158
Car: CAMARO RS
I've looked into it and I think the 4l80e will require more tunnel work than I want to do, so I'll probably get a t56 magnum. If I can get them to let me use an f body ls manifold, will I still need to modify the cats?
Old Dec 22, 2024 | 12:28 PM
  #159
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Yes, the 4th gen manifolds still require cat relocation. The manifolds will clear the a-arm mounts and the starter (another issue with the e-rod manifolds), but the flanges (3 bolt) on the 4th gen parts differ from the e-rod (2 bolt) parts. That said, i tried the 4th gen exh manifolds too...no go. The refs didn't care the instructions say you can substitute other OE Ls exhaust manifolds. Both said i have to use the ones that came in the kit, Maybe you'll have better luck, but id ask first.
Which version kit did you buy? Auto or manual? They have different part #s. If you have the auto version the ECU will be looking for the TCU (so will the ref). The ecu harness has a bulkhead that connects to a female bulkhead on the TCU harness. You cannot change from auto to manual transmissions (or vise/versa). It voids the EO certification. Just like swapping the exh manifolds will do. That's what caused me to fail my first referee inspection.
Old Dec 22, 2024 | 06:41 PM
  #160
Car: CAMARO RS
I bought a used lsa erod kit with a 4l80e.
Old Dec 22, 2024 | 07:43 PM
  #161
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
If the original buyer didnt swap from manual to auto and you want a smog legal swap. You should probably stick with the auto, even if your car is currently manual.
Ive never had an issue with my 4L65e, but the 70e would of been a nice upgrade at the time.
Old Dec 24, 2024 | 09:20 AM
  #162
Car: CAMARO RS
Thank you for all your help. I'm reading the install instructions pdf PN 19369384 the first paragraph on the second page says if it wasn't purchased as a connect and cruise that the vss must be the 40 tooth. After reading all of it it seems like it only requires the vss signal to work, which is part of the engine harness.
Old Dec 24, 2024 | 03:44 PM
  #163
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
I dont have that part# on either my manuals, but the VSS part on the erod says the ECU is looking for 40 pulses/rpm (40T calibration) from the VSS input. Required for emission compliance.
There's also the VSS on the TCU harness for the speedo (optional). Its on the bulkhead connector. Im using it on my dakota digital CC module since my speedo is GPS.
Old Dec 24, 2024 | 08:38 PM
  #164
Car: CAMARO RS
That part number is the lsa erod instruction manual. your manual is for the ls3, but I believe the exhaust is the same.
Old Dec 24, 2024 | 11:33 PM
  #165
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Yeah, but Its mostly the same information with 1-2 paragraphs added/omitted/rearranged or on different pages.
Old Jan 3, 2025 | 05:07 PM
  #166
Car: CAMARO RS
What motor mount set up are you using?
Old Jan 3, 2025 | 07:26 PM
  #167
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Hawks LS swap mounts and GM clamshells.
gt4373
Aug 21, 2018 11:14 PM
gt4373
Jul 24, 2017 09:19 AM
drdan1341
South West Region
Mar 5, 2016 08:47 AM
DISTURBthePEACE
Car Audio
Aug 1, 2003 03:01 PM
