ls1 swap kmember help
Old Feb 24, 2016 | 11:57 PM
mtz.luis's Avatar
Car: 1989 Chevrolet Camaro Rs
I have an 89 camaro rs doing an ls1 t56 swap, cant seem to find the answer to my problem anywhere, tired of scratching my head. mounted the stock k member, which i have already knotched, to the engine and i am having clearance issues with the drivers side manifold. the factory o2 sensor will not clear the k member. its not by much but is obviously an issue. I havent read anything about people modifying the frame on that side to clear the sensor.
Old Feb 25, 2016 | 11:49 AM
R13_Braz's Avatar
Car: 2014 Z28 #80
Re: ls1 swap kmember help
I don't have stock manifold's, but I remember reading that you have to relocate the O2 sensor bung somewhere. Do a search for driver side O2 sensor and see what pops up.
Old Feb 26, 2016 | 06:01 AM
M3638's Avatar
Car: 1990 Iroc Convertible
On the forum ncdave has notched or put a hole in the frame to accommodate that sensor.
On this thread - "91 Z28 California smog legal LS-1/T-56 swap"
Old Feb 27, 2016 | 07:46 PM
WTR388's Avatar
Car: 87 Trans Am
Check my build thread, post #27 I show when I hit this snag.
https://www.thirdgen.org/forums/ltx-...-t56-swap.html
So, I plugged that hole, (welded the head of a bolt in the hole), and when I did my exhaust, I mounted the O2 sensor in the exhaust just after the manifold, positioned the sensor upright in a way that was easy to get to... Which paid off as I had to swap that sensor out, took me 10 minutes, I didn't have to jack the car up to get to it either... I actually did it without seeing it, since I knew exactly where it was, all I had to do was reach for it! A bit of forethought with some stuff really pays off.
kaydoe
Convertibles
Feb 27, 2016 09:41 PM
Vanilla Ice
Jan 22, 2016 07:11 AM
dcd2236
Jan 21, 2016 08:42 AM
usafirebird
Exterior Parts for Sale
Jan 18, 2016 05:02 PM
jorgeblancojr
Jan 17, 2016 06:28 PM
