89 Formula Cruise Control w/E40 ECM
Old 09-08-2016, 10:30 AM
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Axle/Gears: MW 3.42 12 Bolt
I'm looking for some logic info on cruise control stalk (aka, Multi Function Lever).
4 wires:
Pnk/Blk-Blu is the 12V ign in.
Grey? - on/off? If so, I will be using a separate ON/OFF, so I will not be using.
Dk Blue?
Yellow?
Which one is Set/Coast?
Which one is Resume/Accel?
Thanks for your help.
Brian
Attached Thumbnails 89 Formula Cruise Control w/E40 ECM-fig45_1989_body_wiring_continued.gif
Old 09-08-2016, 02:39 PM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
Re: 89 Formula Cruise Control w/E40 ECM
http://ls1tech.com/forums/conversion...l#&gid=1&pid=1
1st post has the info you need
great thread in general though!
Old 09-08-2016, 03:12 PM
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Thanks Jaysz28,
Informative, but not definitive on the wires.
Originally Posted by Pocket
Its 4 wires, colors change with the vehicle
Old 09-08-2016, 05:48 PM
mwfrels's Avatar
Car: '86 Z28
Engine: SDPC TPI 350
Transmission: WC T5
Axle/Gears: 3.23 posi
Found on Google Images:
Green - 12V Switched Power
Yellow - Res/Acc
Blue - Cruise On/Off
Red - Set/Coast
You seem to have two different from that scheme though...
Cheers,
M
Old 09-08-2016, 05:58 PM
mwfrels's Avatar
Car: '86 Z28
Transmission: WC T5
This thread has some good stuff in it you might be able to crossreference: https://www.thirdgen.org/forums/ltx-...e-ltx-lsx.html
M
Old 09-08-2016, 06:38 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Early models, least on my 84.You trying to incorporate this into your aftermarket CC.
From DD, but it didn't really help %100.
Old 09-08-2016, 06:57 PM
TEDSgrad's Avatar
Car: '89 Formula
Engine: LS2
Transmission: 4L65E
Well, almost every bit of info uses the Drk Blue as Set/Coast. That leaves yellow as Resume/ Accel. Thanks guys.
I'm using the CANBUS! I am putting the PIM module between the TCM and the ALDL for the CAN circuit. I'm using a separate on/off switch, but using the stalk for input signals.
Old 09-08-2016, 07:02 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Damn, over my head.
I ended up putting the DD switch in the GM stalk.Required taking both apart, but it works great & looks OE.I tried using the DD schematic, but all I had was set/on/off.No resume or decal & no wipers to top it off if I stuck w/ the DD stalk.
FormulasOnly
06-02-2018 05:44 PM
joekonik
01-08-2017 03:46 PM
machinist21
10-16-2016 08:49 PM
ghettocruiser
10-07-2016 07:13 AM
Markys88
09-06-2016 02:58 PM
Quick Reply: 89 Formula Cruise Control w/E40 ECM
