ls question.
Old Sep 15, 2016 | 10:13 PM
LDR's Avatar
LDR
Car: 2012 Impala ltz 1988 Gta project
ls question.
In about a year i plan on dropping a 5.3 into my gta. I have the chance to work a deal with someone who has a trashed 5.3 out of 2015 silverado. I know its a latter gen I will probably be using a gen 3 or 4. My question is are the blocks actual mounts to the frame in the same location? I was going to see if i can get the block off him cheap to use as a mock up. The motor i am looking at is trashed there is no rebuilding it atualy has a cracked in half piston and several other pistons blown apart so bad u can see the actual rings.
Old Sep 15, 2016 | 11:43 PM
kenney001's Avatar
Car: 1990 Iroc-Z
Engine: 5.7 TPI
Re: ls question.
The motor sits in a similar place, but the engine mounts themselves are different on the block. You need an adapter plate adapters like these:http://www.hawksmotorsports.com/82-9...unt-pads-pair/
Old Sep 16, 2016 | 02:49 PM
Ikes 91Z's Avatar
Car: 1991 Camaro Z28
Engine: LS Conversion
Axle/Gears: Stock for now...
Re: ls question.
Would also be a good for a mockup so you use this block to notch your k member and re-do the wiring harness.
Old Sep 16, 2016 | 04:10 PM
LDR's Avatar
LDR
Re: ls question.
So all ls motors mount the same?
Old Sep 18, 2016 | 06:46 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Re: ls question.
Yes.
Old Sep 19, 2016 | 02:03 PM
Marc 85Z28's Avatar
Re: ls question.
The 2015 Silverado 5.3 is a Gen V engine. It is not an LS based engine. The mounts (locations) are different.
Old Sep 19, 2016 | 09:39 PM
LDR's Avatar
LDR
Re: ls question.
K thanks. I cant belive the damage done to that motor.
90' 305TBI
Sep 13, 2016 01:40 AM
Cody Willey
Sep 10, 2016 05:38 PM
Firechicken86
Sep 10, 2016 12:41 AM
Faolan
Sep 9, 2016 09:30 AM
L6969
Sep 1, 2016 07:33 AM
