using factory starter on ls swap
Old Oct 22, 2016 | 09:48 AM
BlackMamba94's Avatar
Car: 87 iroc z28
Engine: 5.3 under construction
any of you ls swap guys use the starter that came with motor or did you use something else
Old Oct 22, 2016 | 11:06 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: using factory starter on ls swap
MSD dynaforce.
Old Oct 22, 2016 | 11:42 AM
Twin_Turbo's Avatar
The gto starter is a nice small unit. I think its a hitachi starter
Old Oct 22, 2016 | 05:33 PM
WTR388's Avatar
Car: 87 Trans Am
Used a stock f-body ls1 starter.
Old Oct 22, 2016 | 09:06 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
If you end up with an original GTO T56 bellhousing, go with the GTO starter to match.
Other than that oddity, the truck and 4th gen starter work for swaps without issue.
Old Oct 23, 2016 | 07:57 AM
mwfrels's Avatar
Car: '86 Z28
Engine: SDPC TPI 350
Transmission: WC T5
Axle/Gears: 3.23 posi
FYI the GTO starter is manufactured by Mitsubishi and has the pull-in solenoid clocked differently than the F-body or truck starters. This different clocking puts the solenoid protruding more sideways from the engine and can complicate some brands of LT headers if they are in the plan. As JMD stated the GTO bellhousing is the only one that works with this starter as that different solenoid clocking has the starter sitting up closer to the block and interferes with F-body and truck bells.
M
Old Oct 27, 2016 | 04:32 PM
R13_Braz's Avatar
Car: 2014 Z28 #80
I used a new truck starter on mine. LS7 clutch/flywheel setups with LS1 T56 bellhousing. 0 issues.
Old Oct 28, 2016 | 06:59 AM
grngryoutmyway's Avatar
Car: 92 Z28
Axle/Gears: 3.73 10 bolt
Fbody starter, Fbody T56 bellhousing, LS7 clutch, Kooks headers. One of the few things I didn't have issues with
Old Oct 29, 2016 | 10:22 AM
Car: 87 iroc z28
Thanks guys for your help
rce2win
Nov 18, 2006 11:26 AM
