my LS1 T56 swap
Old Apr 12, 2017 | 02:52 PM
91firebird5.0's Avatar
Car: 91Firebird Formula
Engine: 5.0 TBI / Now LS1
Transmission: Auto / Now T56 with stage 2 monster
Axle/Gears: 4/10
my LS1 T56 swap
Hello all I just wanted to share my build so far with a link to an album as I don't have a build thread. The car is a 91 Firebird Formula that had a 5.0 TBI & an automatic that started out as a engine a transmission only swap that grew a lot. After seeing BADNBLK build thread it inspired me to go much further. See album for more, Pictures are always good. Enjoy!!
5.0 T.B.I waiting to come out
engine back in for final mock up
Here is a link to my album that will show much more.
https://www.thirdgen.org/g/album/7251487
Old Apr 12, 2017 | 05:39 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: my LS1 T56 swap
Nice clean swap.
The red intake makes it look like you dry sumped it and stuck it loooooowwwww!
Old Apr 12, 2017 | 08:39 PM
Axle/Gears: 4/10
Re: my LS1 T56 swap
Originally Posted by jmd
Nice clean swap.
Thank you!
I believe it is just the angle of the picture.
Old Apr 17, 2017 | 04:53 PM
robguitargod1's Avatar
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
Re: my LS1 T56 swap
My LS1 is mocked up in the engine bay just like yours and I had to move the #8 coil to prevent it fron putting a hole in the AC box. Did you have that problem?
Old Apr 17, 2017 | 09:22 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: my LS1 T56 swap
You're not imagining things, it will punch a hole. I modified the bracket to move the coil.
https://www.thirdgen.org/forums/ltx-...ml#post5901869
Old Apr 17, 2017 | 09:36 PM
Axle/Gears: 4/10
Re: my LS1 T56 swap
I didn't have that problem as I used the Holly engine mounts and trans cross member which eliminates that problem. it is a great system and I highly recommend it. They also make a really nice set of swap headers and true duel exhaust system.
Old Apr 17, 2017 | 10:06 PM
Ghettobird52's Avatar
Car: 88 Firebird Formula
Engine: LO5 5.7 TBI/Ebl Flash
Axle/Gears: 2.73 stock rear end
Re: my LS1 T56 swap
Did the car/engine bay get painted as well? Lookin good
Old Apr 18, 2017 | 01:55 PM
Axle/Gears: 4/10
Re: my LS1 T56 swap
Gettobird52, yes I painted the whole under side of the car and the engine bay as well. Thank you! I'm happy with the way it came out. If you look at the link to my album in the first post you will see most of what I did to the car.
Old Apr 18, 2017 | 01:58 PM
Axle/Gears: 4/10
Re: my LS1 T56 swap
Sorry didn't realize I didn't have the link on the first post. it is there now.
Old Apr 20, 2017 | 09:52 PM
Axle/Gears: 4/10
Re: my LS1 T56 swap
I finished installing my BMR sub frame connecters, rear sway bar and pbr breaks and rotors.
Old Apr 23, 2017 | 06:21 PM
MustangEater82's Avatar
Re: my LS1 T56 swap
Looking good... I am cleaning and painting the bottom of my car.... hard to keep motivated.
Old Apr 24, 2017 | 06:18 PM
Axle/Gears: 4/10
Re: my LS1 T56 swap
Thanks! it is a lot of work but it is very rewarding when you are finished and it protects the car and make it last that much longer. keep going you can do it!
