87 GTA LT1 swap fuel problem
Car 1987 trans am GTA 350tpi.
New engine 1994 caprice Lt1 9c1 350
i have engine, transmission(4l60e), harness and pcm from same car.
Problem, i have spark, fuel pressure but when i crank the engine dont get any fuel.
if i take a sparkplug out It is dry after crank.
I have Tunercat and have delete vats, 2 posts in switches table in Tunercat.
I think the problem is whit fuel enable signal, dk blue wire 25 red connector on pcm. Wire is cut off near to pcm.
Any idé vhat to do?
/Matte
Any idé vhat to do?
/Matte
Car: 86 Camaro
Engine: '03 4.8 vortec
Transmission: 4l60e
Re: 87 GTA LT1 swap fuel problem
If a/all fuel injectors are not spraying they are not getting power or they are clogged. Run a meter on the injectors connectors on harness to see if they are getting voltage
Are these new injectors or old?
It is something whit power to injector!
I have 12v om both wire to eatch injector all time
Battery is connected.
The pink ones should be connected to ignition switch
After what i can see on wire diagrams.
Is it pcm ignition feed that power the other wire? Pin B30 and D3 on Pcm.
Car: 86 Camaro
Transmission: 4l60e
I'm not sure about the wiring origins. It should tell you on the print. Did you pull the injectors off to see if the spray area is clogged or if they are leaking ? How long have you been having this problem
Here's a link to a '93 F-body Lt1 Injector schematic:
http://shbox.com/1/1993_injector_schematic.jpg
You will see 12 volts on both sides of all injectors until the PCM connects the ground side. PCM turns the injectors on/off by connecting/disconnecting ground. Once you get the PCM signal to the injectors, you may see 12 volts on only one side of the injector. I think the PCM switches the injectors on/off at a fast rate sometimes called fuel injector duty cycle so may be hard to see with a volt-meter?
To test injectors on LT1, take the whole fuel rail off of the intake manifold with 2 or 3 bolts, put paper towel under injectors, crank the engine to try to start, look for fuel on the paper towel.
