LSA in IROC - Hood Clearance
Old Aug 7, 2017 | 03:54 PM
Jeff TX's Avatar
Car: 1988 Camaro IROC-Z
Engine: Dart 427 w Miniram and AFR 225
Transmission: Stg 2 LT1 T56 w/ Spec Stg 3P Clutch
Axle/Gears: QP 9" (3.89) w/ TruTrac
So I've got a sale pending on an LSA/TR6060 setup to swap into my IROC but the one thing that has me trigger shy is the fact that I want to keep the car looking stock on the outside. I'm reading about clearance issues with the LSA in our cars which will require a cowl hood (which I don't want).
I've heard a couple work arounds are to shave the cooling fins off the supercharger and/or use spacers when installing an aftermarket tublar K-member. Any thoughts on these two solutions? Will one of these on their own get my the clearance I need to keep my stock hood? Is one preferred over the other? Any insights will be greatly appreciated.
Old Aug 7, 2017 | 07:42 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: LSA in IROC - Hood Clearance
One of those new LT4 might fit. I hear it is less than an inch taller than the LT1.
Old Aug 8, 2017 | 02:54 AM
Zach/90\irocZ's Avatar
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
Depends what lid your going to run if you want stock hood or not ctsv should clear and that's dependent on motor mounts used and K member used etc
Lt4 should clear also lid is flatter
https://www.thirdgen.org/forums/ltx-...t-left-16.html
Old Sep 16, 2017 | 07:13 AM
85TransAm406's Avatar
Car: 1985 Trans Am
Specific to the LSA, those things are tall up front. shaving the fins gives 3/4" or so at best. custom mounts to lower it are an option, standard mounts I highly doubt will let you clear a stock hood. It would likely take a combination. I do a lot of LSA swaps at work, but specifically to late model trucks and Camaros, along with an occasional SS sedan. My TA is getting one most likely, but I have a 93-97 style ram air hood because I knew it wouldn't clear the stock hood.
Old Sep 16, 2017 | 09:24 AM
Jeff TX's Avatar
I bought a salvaged ZL1. Pulling the engine, transmission and brakes off of it then will part out the rest. I considered the LT4 but they are much more expensive at this point in time.
Old Sep 16, 2017 | 09:26 AM
Jeff TX's Avatar
Thanks guys
Old Sep 16, 2017 | 06:56 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
The "Heartbeat" TVS2300 from Magnusun should fit a camaro hood. the LSA with a CTSV lid may fit.
Old Sep 16, 2017 | 07:36 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Yes, the newer Heartbeat is lower than the older TVS 2300. And the Corvette model is the lowest amongst the model line.
