Upper radiator hose LS3 / LS7 with left-hand pump outlet
Old Sep 22, 2017 | 05:12 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
What upper radiator hose are you guys using that have left-hand water pump outlet?
Old Sep 22, 2017 | 07:32 PM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Transmission: Magnum F
Axle/Gears: TNT 8.8 wavetrac 3.31
Re: Upper radiator hose LS3 / LS7 with left-hand pump outlet
I reused my upper hose from my tpi slight trim to fit stock rad.
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
You staying with the vette pulley spacing?
Old Sep 25, 2017 | 07:30 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
What radiator are you using? Hawks has a kit but I also like the spliced idea that a member did on an LS3 swap into a Bird.
Good photo in post #31
https://www.thirdgen.org/forums/ltx-...-ls3-swap.html
Old Sep 25, 2017 | 02:36 PM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
Attached Thumbnails Upper radiator hose LS3 / LS7 with left-hand pump outlet-0925171015_film2.jpg
Old Sep 25, 2017 | 04:56 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Thanks for the picture. Looks pretty good other than proximity to the power steering pulley. Did you try swapping ends or did it fit better the way you installed?
Old Sep 25, 2017 | 05:28 PM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
It fit this way best the pic makes it look tighter to the pump then it is. I did buy a LS3 Camaro upper hose to use but it didn't fit good at all.
Old Sep 25, 2017 | 05:34 PM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
About 1''
Attached Thumbnails Upper radiator hose LS3 / LS7 with left-hand pump outlet-0925171831_film2.jpg
Old Sep 25, 2017 | 05:38 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
I have an Modine 3 core or something like that. Purchased many years ago. Nothing fancy, just an upgrade from stock 3rd gen.
That splice from "Jags That Run" is used widely by people at this site. If you have a manual transmission then you might want to take a look at what I did because you won't find a cleaner steam line install anywhere on this site. My engine will self purge without any tricks, manual bleeding, or any effort other than adding coolant.
Post #367, https://www.thirdgen.org/forums/ltx-...ml#post6007530
Old Sep 25, 2017 | 05:50 PM
obeymybird's Avatar
Car: 92 camaro RS
Engine: LSA
You can just see my steam line hookup into the back of my water pump in the above pic works great very stealthy.
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Originally Posted by obeymybird
About 1''
With my luck that will make incidental contact with the pulley. The hose gets pretty heavy when full of coolant, and more flexible when hot. I'd feel better with something that I can strap to the upper radiator shroud.
For reference, my hose is 5" away from the pulley today and is strapped to a support cup built into the fan shroud. I have a dual fan radiator shroud that looks different than yours. It really does look like the hose would fit better if flipped in my case.
Chevykid810
Sep 11, 2018 03:41 PM
89ROC-Z
Oct 1, 2017 11:04 AM
91_B4C_RS
321
Jun 16, 2014 04:11 PM
Tricked-Out-Toy
Jan 24, 2014 11:43 AM
3rd gen Will
Mar 27, 2010 10:06 PM
