vss hook up painless harness
Old Sep 26, 2017 | 09:31 PM
calmhotrod's Avatar
Car: 89 firebirdformula
Engine: lt1 5.7
Transmission: 700r auto
Axle/Gears: stock as of now
i have a green wire from my painless harness I found output buffer box do I hook vss wire from painless harness to the green wire on buffer box for speedo to work
Old Sep 26, 2017 | 09:34 PM
calmhotrod's Avatar
Engine: lt1 5.7
Re: vss hook up painless harness
hello
Old Sep 26, 2017 | 09:37 PM
calmhotrod's Avatar
Engine: lt1 5.7
any help plez
Old Oct 9, 2017 | 08:21 PM
marcial88's Avatar
Car: 1986 Camaro Z28
Engine: TPI 305 CI 5.0L V8 LB9
Transmission: AUTO 4 SPD 700 R4
Axle/Gears: 3.23 RATIO
im in the same boat as you. i read somewhere that we can buy an adapter of some sort to hook it to the vss.
Old Oct 21, 2017 | 12:07 PM
Pocket's Avatar
Car: 91 Trans Am
calmhotrod, you 89 bird has an electric speedo. Find the dash side C207, pin K BRN. Splice the painless speedo wire here. Find the buffer box right above it and unplug it. Jump pins C&F. Done
marcia, your 86 camaro will have a mechanical speedo, so there is an extra part needed to convert the electric signal into mechanical motion. I recommend the cable-X box, simple three wire hookup. Power, ground signal
clodfeb
Oct 17, 2017 11:34 AM
tylercamaro
Sep 7, 2017 10:12 AM
Blu_roc
Sep 2, 2017 04:18 PM
Justin93
Aug 30, 2017 04:31 PM
Brett Sanborn
Carburetors
Jul 11, 2017 05:55 PM
