im having trouble starting my third gen camar
Old Oct 5, 2017 | 01:46 PM
marcos9499's Avatar
so i bought this 1985 camaro the guy i bought it from swapped the engine with and lt1 from a 1994 camaro z28 he used a computer from that camaro as well but i have fuel and spark but the injectors arent injecting
Old Oct 5, 2017 | 01:55 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: im having trouble starting my third gen camar
Vats maybe ?
https://m.ebay.com/itm/GM-VATS-or-PA...%257Ciid%253A1
Old Oct 5, 2017 | 01:59 PM
marcos9499's Avatar
maybe, i was told it might be a crank sensor
Old Oct 5, 2017 | 02:06 PM
Engine: Lb9
Transmission: M20
https://www.1aauto.com/content/artic...sensor-testing
You might want to get a schematic and check the vats hz signal or contact the eBay member who sells the hz modulator and ask what pin of the ecm is for vats.have a obd2 code reader or scanner ?
Last edited by Tuned Performance; Oct 5, 2017 at 02:18 PM. Reason: Additional information
Old Oct 5, 2017 | 02:29 PM
Engine: Lb9
Transmission: M20
Key on you will see about 2.5v I think this is a 30hz signal at 50-60%.
Old Oct 5, 2017 | 02:51 PM
marcos9499's Avatar
yes i do have one
Eric-86sc
Apr 27, 2017 11:28 PM
WhiteSnake91
Mar 21, 2017 10:33 AM
Linson
Jan 22, 2017 05:35 PM
dereklicon
Dec 3, 2016 04:39 PM
86FyrBrd
Car Audio
Nov 10, 2001 09:37 AM
