Fuel pressure regulator
Old Mar 1, 2018 | 07:47 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
Guys, i'm debating on what to do to regulate the fuel pressure on my ls swap. everyone seems to use the corvette filter/regulator. by the time you buy all the fittings, hoses, etc it's almost the same cost as going with the hawks aeromotive fuel regulator without all the work.. thoughts?
Old Mar 1, 2018 | 09:16 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Fuel pressure regulator
BPR Hotrods sells a nice setup with the C5 regulator and lines for $399. They also have a kit with and adjustable regulator for $499.
Old Mar 2, 2018 | 12:21 AM
camarotucker's Avatar
Car: 91 z28
Transmission: 4L60e
Axle/Gears: 10 bolt 3.42
Work, lines, and cost aside, the Corvette Regulator got my nod because in the event of regulator failure you could have the Corvette one changed out on the side of the road in minutes vs. a tow and a few days for Aeromotive replacement.
Old Mar 2, 2018 | 08:07 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
that was my thought also... but the rebuild for the aeromotive is cheap i could have one in the car in case.
Old Mar 2, 2018 | 08:33 AM
redmaroz's Avatar
Car: 92 Z28
Engine: ls3
Transmission: t56
Axle/Gears: 4.11
The other benefit of the corvette regulator is you do not have to mess with adjusting the pressure, just run it and go.
Old Mar 3, 2018 | 03:17 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
i ended up ordering the hawks one, they have 10% off deal going on right now.
Old Mar 5, 2018 | 08:29 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Which kit of theirs did you go with?
Old Mar 5, 2018 | 09:10 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
i went with the trickflow midnight with hoses made by aeromotive.
Old Mar 25, 2018 | 08:24 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
so i was looking at the regulator and the fuel rail quick connect adapter hawks sent doesn't fit. it's 5/16 and the fuel rail is 3/8
tompumped
May 29, 2018 05:18 PM
TheFleshRocket
Dec 19, 2003 03:42 PM
Hawaii 5.0
Jun 3, 2001 10:27 PM
