84 Berlinetta swap project
Old Mar 9, 2018 | 04:39 PM
SteelDirigible's Avatar
Car: 84 Berlinetta
Engine: LR4
So, I hadn't planned on starting this yet, but I am picking up an engine next week and ended up buying some swap components today. eBay is running a promotion for 20% off ANYTHING with code PSPRING20 for today so I took advantage.
Plan so far:
-truck engine
-using 700r4 for now to be upgraded to a t56 at a later date
-tubular k member (I have no fabrication skills)
-learn as I go. First ls swap but I want to jump right in.
So I ordered my LS1 oil pan kit from Jegs ebay store ($206.58) and the Speed Engineering headers from their ebay store ($298) and with the 20% off that was $398 for both. Not bad.
My question now is that I want to buy a K-member today from Hawk's ebay store and I'm having trouble finding the right one, particularly using the ebay store to do so. There are several part numbers listed for the Spohn.
Here is the ebay link to their k-members:
http://stores.ebay.com/Hawks-Third-G...r+82-92+camaro
What's the difference between the 703 and 704? Some are listed as SP-704 or DP-704, what is the meaning of this?
I will be keeping factory A-arms and AC, I believe I can relocate AC but just throwing it out there.
Also, would these be the right motor mounts for the Spohn K-member:
https://www.ebay.com/itm/Camaro-Fire...-/311817032827
Old Mar 9, 2018 | 09:44 PM
Car: 84 Berlinetta
Engine: LR4
Re: 84 Berlinetta swap project
So I ordered this k member using the ebay code again to get $100 off. Pretty nice.
https://rover.ebay.com/rover/0/0/0?m...2F381931763175
Should be the right one I think.
Old Mar 10, 2018 | 07:32 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Great buys with that code. I tried to use it twice and it wouldn't let me. What was your trick?
Old Mar 10, 2018 | 07:36 AM
Car: 84 Berlinetta
Engine: LR4
I made another ebay account. A lot easier than I thought it would be, you can link up to 8 accounts to the same PayPal. With the headers and oil pan I added both to cart so it was one order even though it was different sellers it was applied to both items.
Old Mar 10, 2018 | 08:17 AM
Car: 84 Berlinetta
Engine: LR4
Here's the car this is going in. 1984 Berlinetta 305 auto. 305 is seized up but I'm tearing it down while I get my ls stuff together. Digital dash does work so I'll keep that. I'll also be bolting up to the stock 700r4 because I want to swap to a t56 later but I don't have the money right now. I also plan to upgrade the 4.8 down the road but for now I would like to get it in and running in stock form.
I'm picking up a 4.8 Monday with harness and computer. Planning to try and do wiring myself. Once I get my stock harness out of the camaro I guess I'll get started figuring that out this week.
Attached Thumbnails 84 Berlinetta swap project-afa5b695-87cf-4033-9f6a
Old Mar 11, 2018 | 11:26 AM
Car: 84 Berlinetta
Engine: LR4
Is $450 for a 4.8 with computer and harness a good price? The $350 I was quoted was without the core charge. Didn't mention a core charge until they had pulled the motor for me. It's an 03 with 190k miles. 30 day warranty but I don't know if I'll get it in that soon.
Old Mar 13, 2018 | 06:49 PM
Car: 84 Berlinetta
Engine: LR4
Got the first piece in today! The ever exciting oil pan
From Jegs. weird, all the pieces were loose in the box, so I had pan bolts falling all over. Found a couple stuck up inside the oil pan after I came up short on the initial count.
I guess I need to get an engine for it now. Should be getting that tomorrow.
And here's some Harbor freight toys I got myself. Can you tell it's my first swap?
Attached Thumbnails 84 Berlinetta swap project-img_6867.jpg   84 Berlinetta swap project-img_6870.jpg   84 Berlinetta swap project-img_6869.jpg
Old Mar 13, 2018 | 11:08 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Oil pan looks deep, kind of like some aftermarket version of the truck oil pan. Might hang really low under the car and get smashed.
Old Mar 14, 2018 | 04:02 AM
Car: 84 Berlinetta
Engine: LR4
I kind of wondered but I have nothing to compare to. It said it was for the ls1 so I assumed it was the right depth.
Here's the link.
https://rover.ebay.com/rover/0/0/0?m...2F111059732055
Anybody have the dimensions on the depth it should be to not drag?
Old Mar 14, 2018 | 04:14 AM
Car: 84 Berlinetta
Engine: LR4
Factory pan is right at 6". This is just under 8" at the deepest. Guess it won't work. I wish they'd or dimensions in the listing. Is there a jegs part number I should use? I'd like to be able to do an exchange to pay the difference because I won't be able to use my 20% off again. But my priority is not smashing my oil pan
Old Mar 14, 2018 | 08:26 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Exchange it for an F-body pan. You'll need the windage tray and pick-up tube as well.
Old Mar 14, 2018 | 08:52 AM
Car: 84 Berlinetta
Engine: LR4
I'll return it. I'll get the correct fbody pan when I'm closer to putting the engine in. I have plenty to do before the engine goes in anyway. Learning experience for me to do my research better and pay attention to what I'm buying. I see now in the listing it shows the dimensions of the pan.
Old Mar 14, 2018 | 03:09 PM
Jaysz28's Avatar
Car: 91 Firebird
Engine: 6.0
make sure to read the stickies here and on LS1tech
Definitely a lot of info to help avoid that type of thing from happening.
Old Mar 14, 2018 | 11:07 PM
Car: 84 Berlinetta
Engine: LR4
Oh I've read em. It just didn't stick. Haha. I'm a hands on learner so I'll make some mistakes. I got a little anxious trying to jump into things but now I can slow down a bit. Hopefully I won't embarass myself too much more.
So I have an engine now. 4.8 with 190k miles. It will end up getting rebuilt so I will be doing my research to see what I want to do exactly in that regard. In the meantime I have a 305 to pull and a wiring harness to wire. Also have my speed engineering headers.
Attached Thumbnails 84 Berlinetta swap project-8cff8e3c-4876-47fc-9e62   84 Berlinetta swap project-f139c448-47e0-4914-8ae7
Old Mar 15, 2018 | 01:54 AM
BlackMamba's Avatar
Car: 84 Camaro Z28
Engine: 355 Carb
Following
would like to see how it turns out
Old Mar 15, 2018 | 02:18 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Your options are almost endless. You can stay 4.8, make it a 5.3, 5.7 or even a 383. The key will be figuring out how much power you want to make. That will dictate the type of parts you go with and ultimately your budget. Sometimes it is easiest to do a simple rebuild with a small cam, get it running and go from there.
Old Mar 15, 2018 | 02:38 PM
Car: 84 Berlinetta
Engine: LR4
I do think at this point I just want to get everything in and running. I have plenty do and learn without throwing a rebuild on top of everything, plus the funding is a little dry. I may even just leave the truck intake on and the hood off, assuming I can pass inspection without a hood.
bare minimum to get going I need my oil pan, motor mounts, and prep my wiring harness. Starter, alternator, power steering are missing too. Also my exhaust. And fuel pump. So quite a bit still.
Since I'm planning to upgrade to a T56 later, I'll plan to do my engine work then too. Also the reason I want to do the wiring myself, so that when I convert to manual I'll already have a good understanding of where my wiring is.
Old Mar 17, 2018 | 03:25 PM
johnw999's Avatar
I’m a fan but f the ‘84 model, and I look forward to reading updates on your project. I did an LS swap on an ‘84 Trans Am. I used a 5.3 engine, and I bought f-body ls1 parts for it (oil pan and accessory drive). Texas Speed and Performance helped me witn my cam choice, and I’m pleased with it. They responded quickly and directly when I emailed them. This website has C100 plug diagram info if you need it:
http://berlinetta.info/C100.htm
Old Mar 20, 2018 | 02:11 PM
Car: 84 Berlinetta
Engine: LR4
So thanks to another spring ebay code for 15% off (pspringtime) max of $50 I ordered the CORRECT oil pan this time from Hawks on ebay. $320 after discount for the kit.
Just need motor mounts now to actually get the engine in the car, and was curious about the clamshells which Hawks sells in pairs for $188 and rock auto has mounts for $72 a piece for the ac Delco, but there's also several options as low as $23 for the clamshells. Is it worth getting the Delco parts or does it make a difference? Does anyone have experience with the cheap ones?
Link to them on rock auto:
https://www.rockauto.com/en/catalog/...tor+mount,5552
Old May 9, 2018 | 12:36 PM
Car: 84 Berlinetta
Engine: LR4
I have not made much progress. I'm starting to look at wiring and it doesn't look that bad, but I'm also a little scared to start cutting my harnesses up. As far as that goes, should I basically end up with a single harness that plugs into the c100 plug and goes to the engine?
I'm also a little confused with the factory 4.8 harness. If I have the complete c2 connector, why is the easiest thing not to just get the fuse block for it and give it power? Then I would just need to pull a few wires that will go to the c100? is that right? Do I really need to remove all the pins I'm not using from the pcm or can I just leave them?
And what is the harness on the passenger side that comes out the firewall? Where is the pinout for this, does this go to the passenger kick panel?
Old May 9, 2018 | 12:38 PM
Car: 84 Berlinetta
Engine: LR4
Got the heads off the 305 so now I'm trying to get it unseized so I can pull the block. Here's what the drivers side cylinders look like.
If I can't get it unseized to get all the torque converter bolts, how can I pull it from the car? I don't need to pull the whole transmission do I?
Attached Thumbnails 84 Berlinetta swap project-img_7203.jpg   84 Berlinetta swap project-img_7204.jpg
Old May 9, 2018 | 12:58 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
The trans has to come out anyways so might as well pull both. Since you took the top end of the motor off you may want to lift the car and lower the entire drivetrain out of the bottom. You can do it with your basic engine lift.
Old May 9, 2018 | 08:10 PM
Car: 84 Berlinetta
Engine: LR4
Why does it have to come out anyway? You mean because the engine is seized, or some other reason? I was under the impression I could bolt up to the 4.8?
I have a new k member anyway, so maybe I should just drop it out the bottom.
Old May 10, 2018 | 07:59 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I'd have to refresh my memory on auto trans compatibility but it is hard to separate the two while they are in the car. I find it easier to remove the whole drivetrain. If you are installing a new K-Member it can be even more beneficial for you to do it that way.
Old May 11, 2018 | 09:53 AM
Car: 84 Berlinetta
Engine: LR4
Thanks, I'll look into it. If I'm wanting to swap to a t56 down the road, should I really just consider biting the bullet and doing the whole package? Is it a huge hassle to rework the wiring after the fact? I'm kind of thinking I should just get the t56 and rebuild the engine while I have it all out to save me some work, just be a lot longer getting it all together and funded.
Old Jun 11, 2018 | 07:13 PM
Car: 84 Berlinetta
Engine: LR4
I was tempted once again by a 20% off code on ebay. Got motor mounts, water pump spacer, and alternator/ps bracket to drop the alternator. I didn't want to do a low mount alternator because I wanted to avoid tapping my block. $80 for the mounts from Hawks, $24 for the water pump spacer and $150 for the accessory bracket, both from "lsx innovations" on ebay. Mocked it up on the engine, looks pretty good. Don't have my accessories yet. Ac compressor will stay low mount.
Attached Thumbnails 84 Berlinetta swap project-e158b508-9352-40c2-a2b1   84 Berlinetta swap project-b884c3ca-1be1-4a9c-b5ac   84 Berlinetta swap project-bb1e05f1-b51d-46cf-93a8   84 Berlinetta swap project-76b899fa-1efe-4491-b74c
Old Jun 11, 2018 | 07:38 PM
Car: 84 Berlinetta
Engine: LR4
I haven't gotten the old engine out yet. That's why I haven't got any real progress. Need another set of hands or to get the engine unseized and I've been busy. Spent time looking at the harness though figuring out as much as I can before I start cutting it up.
Old Jun 12, 2018 | 02:01 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
...........I'm also a little confused with the factory 4.8 harness. If I have the complete c2 connector, why is the easiest thing not to just get the fuse block for it and give it power? Then I would just need to pull a few wires that will go to the c100? is that right? Do I really need to remove all the pins I'm not using from the pcm or can I just leave them?
When I converted to the LT1 I did exactly what you describe. My 84 didn't have wiring, fuses, or relays for many of the electrical accessories that needed to be added to the car, So I swiped an under-hood fuse/relay center from a 4th gen and ran all the additional electrical stuff ( Fuses and relays for Fans, Fuel Pump, Water Pump, Fog Lights, PCM, ect..... ) thru that. In my case any un-needed wiring was removed and PCM commands were programmed out of the PCM, but as long as the wires are well insulated they can get left in place and just hidden inside the looms.
This might help:
C100 for the 84 Berlinetta ( Drivers side firewall ) :
Here is the C207 wiring ( ECM harness thru pass side fender to dash harness )
1984 C207
PIN Color From / To (Notes)
A Brn ALDL / ECM (AIR control)
B Dk Blue BU Fuse / Back Up Switch ( T5 only )
C Wht/Grn Light Driver / ECM
D Tan Oil Pres / Gauge (L4)
E Wht/Blk ALDL / ECM (test)
F Pnk/Blk IGN fuse / EGR-ECM
G Lt Green BU switch / Rev Lights ( T5 Only )
H Tan/Blk ALDL / TCC-ECM
J Org ALDL / ECM ( L4)
K Brn ECM / VSS
L Tan/Wht Fuel Relay / Fuel Pump ( L4 )
M Blk/Wht VSS, P/N switch / Grd
N Org/Blk ECM / P/N switch
P Ppl Brake / TCC ( V8 )
R Ppl Crk Fuse / EFI (L4)
** There are 2 things that make a 84-86 Berlinetta C100 ( ENGINE harness ) specific to only those cars and unlike any other Thirdgens:
1) There are 2 VSS wires for the electronic speedo sending unit
2) The Window Wiper Assembly Plug/Wiring
Did you cut up your original Engine harness yet ??? If not; I'm pretty sure that I've got a partially hacked Berlinetta C100 engine side connector. If your interested in it send me a PM,... if I hear back from you I'll dig it out for inspection to see what kind of shape it's in. You know what; I think I might still have a spare 4th gen fuse/relay center too....... ?!?
<Edit> P.S. Pull the engine and tranny at the same time. I pull drive-trains solo,.........it's just easier to pull them out together. The front of the engine will need to be very high to make pulling them out as 'smooth' as possible.
Old Jun 12, 2018 | 08:02 AM
Car: 84 Berlinetta
Engine: LR4
What are the implications of the two VSS wires? Will I need to use both?
I haven't cut up the original harness. I'm still debating how to do the wiring. I watched the youtube videos from the LT1swap.com guy where he rewires the ls harness, and it really doesn't look that bad either. I did get a generic fuse box for free that will hold a few relays and blade fuses so I can use that if I go that route.
You just pull it out the top like that? That definitely seems easier/safer to do solo than the bottom. I'll look into that because the engine is pretty well stuck. Once that comes out I'll be in a good place to start working on the next phase.
Old Jun 12, 2018 | 11:00 AM
John in RI's Avatar
On the Tranny wires,..... how you deal with the tranny VSS wires is gonna' depend on the tranny that you decide to use. The 700R4 in your car now uses a 84-89 electric speedo sending unit. The speedo signals go from the tranny to the Speedo Buffer Box, then out to the ECM, Cruise Control, and Digital Cluster.
If you plan to retain the original digital cluster and use a 700R4 then you're probably all good- at least as far as the speedometer readout. ( I'm not sure if or how the 4.8 PCM speed signal needs to be handled with an auto tranny car. ) I swapped to a T56 using a stock 4th gen speedo sending unit in the tranny and in order to get the digital speedo working properly I removed the stock Speedo Buffer Box and replaced it with a Dakota Digital SG5.
Old Jun 12, 2018 | 11:51 AM
Car: 84 Berlinetta
Engine: LR4
I do want to keep the digital dash, and for now I plan to keep the 700r4, so that should be easy enough. I'll do some research on the VSS inputs to the 4.8 pcm.
My plan for the future is to go to the T56, so you just used the Dakota Digital box with that? to work with the digital cluster?
Didn't realize the Berlinetta site was yours! I've been referencing that quiet a few times during my research.
Old Aug 2, 2018 | 09:12 AM
Car: 84 Berlinetta
Engine: LR4
Well I finally got my engine out. Not too exciting of an update for you all but I'm very happy to have finally gotten this done so I can get to the fun part. What I did to free it up was take off the oil pan, lift up the engine tranny up enough to pull the pan out, and unbolt the seized pistons from the crank. From there I was able to get all the torque converter bolts out. I just pulled the block out the top, didn’t even have to remove the hood since I had it torn down to the block anyway.
So while I work on dropping the k member and suspension parts, I've ordered some more toys from rock auto. I got a TYC starter and alternator, never heard of them but they have a lifetime warranty so I'll hold them to that. Also got my engine side motor mounts, and valve cover and intake gaskets and new idler pulley. Still need some more various parts here and there but the list is thinning out. I am leaving the original suspension components for now, I really wanted to go ahead and replace everything but I decided to save my money for swap issues that will probably come up. Maybe in the spring I will replace it all but I am just doing the minimum to get this engine running in the car for now so I can get inspected.
What hardware should I replace vs reuse? I am guessing I should get new flex plate to torque converter bolts, what about the bellhousing bolts? Motor mount bolts? Can I just reuse the long bolts from the sbc or are the different sizes? I have all new hardware for the k member and intake. I’m not disassembling the engine other than the new intake going on and valve covers replace just to check things out up top.
Attached Thumbnails 84 Berlinetta swap project-5eaef5fe-016f-4361-94cc
Old Aug 2, 2018 | 09:36 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
If the bolts are in good shape, just clean them up and reuse them. They aren't torque to yield so you don't have to toss them. Cleaning them well though ensures you get a reliable torque reading when you put them back in.
Old Aug 2, 2018 | 12:12 PM
Berlinettaowner's Avatar
Car: 1985 Camaro Berlinetta
Engine: 2.8L V6
Definitely following. Mine needs a new tranny anyway so I've been looking at a swap
Old Aug 6, 2018 | 09:26 AM
Car: 84 Berlinetta
Engine: LR4
I'm going to track all my expenses as well. Here is the google sheets document I will be using. Currently at $3700 including the car. You can see exactly what parts I bought with part numbers, I need to update/add some info but the basics are there now.
https://docs.google.com/spreadsheets...it?usp=sharing
I will be adding a category later for stuff from the car I sell. So far got $35 back in parts (woo hoo)
Old Aug 6, 2018 | 06:44 PM
Car: 84 Berlinetta
Engine: LR4
I’ve got an exhaust stub broken off in the head. Trying to figure out my best course of action here. Tried drilling out the stud and using a screw extractor, but the extractor broke off in the stud (studception??)
I can’t weld and don’t have a welder. My options are to find a friend, take it somewhere, or buy a new head, either a replacement 862 or upgrade to the 243s or something. I didn’t really want to spend that much though.
Any my tricks for getting it out without a welder and is it worth doing vs just getting a replacement 862 head for $110 on eBay? Or should I just bite bullet and get better heads now, or even a new engine, 5.3 or something?
Easiest option, what if I just ignore the bolt and leave it out of the headers? I mean I'm sure it'll leak but it'll allow me to work out the swap and worry about the heads later.
Old Aug 7, 2018 | 11:16 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
It's probably a good idea to just take the heads off anyways. Send them to a shop to have the broken stud fixed and have them clean up the valves and replace the valve springs. You can then clean the deck, inspect the pistons and run new head gaskets. This could be a blessing in disguise in the long run.
Old Aug 7, 2018 | 11:44 AM
Car: 84 Berlinetta
Engine: LR4
You know, I'm sure you're right. I was looking to cut corners because I'm anxious to get the project done. But I think I've decided, literally just now, that I'll take my time with the engine. I have too much to do and a long winter ahead, so while I have it out I will just stall on putting it in and go ahead and freshen things up. I'd like to do cam/springs together, so I'll do some research on where to go with that.
Think it's worth having work done on the 862 heads or would that money be better spent on getting 799/243s? From what I've read previously might be better off, if I'm at the point of putting any money into the 862s I could just upgrade them. If I upgrade springs now and upgrade heads later I can just swap the springs out, correct?
Think I need to do anything with the bottom end, assuming it all looks good?
Old Aug 7, 2018 | 12:15 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
A ported set of 862 heads will support more power than people think. When you port 243/799 heads and use them on a 4.8/5.3 you often end up with a head that has a too large of a port and you affect the coefficient of discharge. Meaning, you would have a lazy head and lose power under the curve only to gain a few up top. Your engine is small, and those heads can easily support 450hp+ when ported. IMHO, unless you were running a 346 or larger I would keep what you have. There are many shops that have affordable porting services for those heads. Advanced Inductions, TEA, Texas Speed, Frankenstein, Land Speed, etc. Depending on your power goals porting might not even be needed. A valve job, and a bump in compressor goes a long way with these motors. The heads flow around 260cfm stock or so on a 3.9" bore. Talk to your local engine shop. Make sure they have experience with LS stuff and see what they have to offer.
Old Aug 7, 2018 | 08:17 PM
Car: 84 Berlinetta
Engine: LR4
Will do.
Taking my front struts out today so I can drop the k member and I got one, the other strut stud sheared off 😑
What's the best way to get it out now? Can I just unbolt it from the spindle and pull the assembly out the top?
Attached Thumbnails 84 Berlinetta swap project-867d4599-62ee-4e9b-8a62
Old Aug 8, 2018 | 08:59 AM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Grind a slot in that stud for a screwdriver. Try to get the nut off with a wrench. You might get lucky just hitting the nut with an impact.
Old Aug 9, 2018 | 09:33 PM
  #42
Car: 84 Berlinetta
Engine: LR4
Apparently I'm not very good with an angle grinder. Couldn't make a good slot. Ended up hitting it some more with an impact wrench and eventually it started to turn so got it popped off that way. It soaked overnight with some PB blaster.
Also got some bolts cleaned up, soaked in degreaser then vinegar (some skipped the degreaser). Soaked overnight and today I scrubbed them. Came out pretty well. They certainly don't look 34 years old. These are the control arm bolts and motor mount bolts.
And another positive note, I got my power steering pump today. My engine didn't come with a ps pump, alternator, or the bracket. The other day I ordered a pump on ebay from LKQ, a company I'd never heard of. Funny enough, I saw an LKQ truck today running around Kentucky. Anyway, I bought that particular one because it showed the pulley with it. Since mine didn't have anything, to buy new I would have to buy a pulley ($20) plus a new pump PLUS core charge since I don't have an old pump. Well, I bought this for $38 assuming it would come with the pulley. Not only did it come with the pulley, it had the bracket and idler pulley as well. It was well worth it, even if this pump with 111k miles doesn't last because it will save me a core charge and get me a pulley.
Attached Thumbnails 84 Berlinetta swap project-17d85872-c83d-4f1e-be30   84 Berlinetta swap project-1c583ba1-9f92-46dd-8dee   84 Berlinetta swap project-24ef84ed-6ab3-47e9-9762
Old Aug 16, 2018 | 03:17 PM
  #43
Car: 84 Berlinetta
Engine: LR4
I'm debating how much of the engine I want to get into. I guess I am looking at pulling the heads and have them worked over by someone who knows what they're doing. What else should I look at doing before I put the engine in? I really just want it to not blow up, but I wouldn't mind going ahead and getting a cam and springs to match while the heads are getting redone. I don't really want to get into the bottom end too much if I can help it. Would it be a good idea to go ahead and put in a new timing chain while I'm at it? Any other worthwhile upgrades while I have the engine opened up?
What are the cam recommendations for the 4.8?
Old Aug 16, 2018 | 03:26 PM
  #44
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
I would at the minimum replace the timing chain and lifters. You can buy a set of LS7 lifters for $100. Cheap insurance. I would also put in a trunion kit in the rockers. Other than that, just replace any gasket that you break free.
As for cam, depending on your supporting mods, gearing, driving style, and goals your options are endless. I would assume you want something a little bigger than stock but with overall good drive ability? Since your budget oriented look for a used LS6 cam. If not, be prepared to spend at least $300 for an off the shelf grind.
Old Aug 16, 2018 | 04:18 PM
  #45
Car: 84 Berlinetta
Engine: LR4
I wouldn't care to spend more and sacrifice some driveability to get some more performance, actually. I had looked at the ls6 cam a little, it's $290 new so I can keep an eye out for used, but I also don't care to get something $3-400. What kind of specs should I look at if I wanted to get something more aggressive than the LS6 setup?
The only other performance stuff I have plans on for now is what I have, speed engineering headers and ls6 intake, and some sort of exhaust.
Old Aug 16, 2018 | 07:23 PM
  #46
irishhockey34's Avatar
Car: 92RS
Engine: LQ4
Transmission: 4L80E
hey does that lsx innovations alt/ps bracket allow you to use the factory truck alternator and ps pump? If so what is the part # or link? I'm trying to figure out accessories on my build and that bracket looks nice!
Old Aug 16, 2018 | 07:57 PM
  #47
Car: 84 Berlinetta
Engine: LR4
Here it is. It is for the truck accessories and the truck spacing, just lowers the alternator a bit. $190 but I used a discount code on ebay when I bought it.
https://www.lsxinnovations.com/produ...ering-bracket/
Old Aug 16, 2018 | 08:15 PM
  #48
Car: 92RS
Engine: LQ4
Transmission: 4L80E
Awesome! Do you know if it clears the stock thirdgen hood? Looks like it should. Sure beats buying a whole f body accessory drive.
Old Aug 16, 2018 | 10:24 PM
  #49
Car: 84 Berlinetta
Engine: LR4
I don't know that it does, but I'm sure hoping so! it's lower than the factory truck bracket, so it should be fine.
Old Aug 16, 2018 | 10:26 PM
  #50
Car: 84 Berlinetta
Engine: LR4
https://sdparts.com/i-22100609-sdpc-...5-560-114.html
Looking at this cam with the ls6 springs, I'm still figuring out cam specs but it SAYS it's just a step above the LS6 cam. Any thoughts?
