p0200 code
Old Jun 2, 2018 | 09:17 PM
Formula Fore's Avatar
p0200 code
Ive been dealing with a P0200 injector open circuit code for a few days now and im completely stumped. Today I checked the ohms on the injectors and they were fine, I checked the voltage of the voltage feed wires and they all read 12v+.
I ended up finding a signal wire that was broken off from the injector connector, so I soldered it back on and checked the rest for safe measure and they all checked out fine. I started the car and let it run for about 10 minutes and it ran perfectly and the codes disappeared as well, so i went ahead and loomed the harness back up and started the car again.... bam the code is back and it has a very rough idle. I removed the harness again to see if I accidentally pinched anything and I see nothing wrong with it, anyone have a clue of what could be going wrong here?
Old Jun 4, 2018 | 09:10 PM
Re: p0200 code
Update* I fixed the issue turned out to be a cut in two wires and they were touching each other so i heat shrinked each one and it works perfectly now
STREETDEMON
Sep 24, 2012 08:15 AM
sqzbox
Sep 28, 2003 10:03 PM
KED85
Feb 13, 2002 10:07 AM
Jax86SC
Jul 2, 2001 10:17 PM
Christos
Nov 17, 2000 05:23 PM
