Need a lt1 bin file for first startup
Old Jun 7, 2018 | 09:52 AM
92rally_sport's Avatar
Car: 1992 Camaro RS
Engine: 305 :c
Transmission: t5
Ive got a few bin file that will probably work but I'm wondering if anyone use a bin specifically for my cam or one very close. Its a 94 pcm.
lunati Cam http://www.lunatipower.com/Product.aspx?id=2553
1.6 roller tip rockers
light port job and 2.0/1.56 valves
stock tb and injectors at least until I get it running
Mid length headers, 1 5/8 I believe
I'm not looking for a perfect tune just something I know is going to fire and at least let it run decent enough until I can datalog some. Thanks.
Old Jun 7, 2018 | 10:17 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Need a lt1 bin file for first startup
Take a stock bin and set your injectors and a faster idle speed
It should start up on that cam just fine. I did that cam in a 94-95 i believe, it didnt take alot of adjustment
Old Jun 7, 2018 | 02:32 PM
Car: 1992 Camaro RS
Engine: 305 :c
Transmission: t5
Since I'm using the stock injectors temporarily what do I need to change with the injectors? I'm guessing I'll have to play with the fuel tables to give it more fuel everywhere but I'm very new to tuning with tunerpro on my laptop.
Old Jun 7, 2018 | 06:34 PM
Thirdgen89GTA's Avatar
Car: 1989 Trans Am GTA
Transmission: M28 T56
It will run on that tune. Not great, but it will run. Most likely rich as hell at idle. And leaner up top.
My LT1 fired up with a stock bin and I had heads/cam/intake/exhaust.....
All I did was change the injector constant to match the injectors I was running. Its an easy change to the tune.
Old Jun 7, 2018 | 09:53 PM
Car: 1992 Camaro RS
Engine: 305 :c
Transmission: t5
So since I'm using stock injectors just make sure injector constant is 24? And I'll probably bump the idle up 2 or 3 hundred rpm.
Old Jun 8, 2018 | 06:52 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
In that case leave them. I assumed you might have changed injectors. Thise should be near enough for that power
Old Jun 9, 2018 | 07:49 AM
Car: 1992 Camaro RS
Engine: 305 :c
Transmission: t5
Alright I'll try just increasing the idle speed a little bit and start it on the stock tune, I should be starting it early next week. Thanks
BOTTLEDZ28
24
Oct 26, 2017 05:25 PM
327_TPI_77_Maro
Jan 19, 2005 12:03 AM
87transam5.7tpi
Jan 26, 2002 02:34 PM
doc
Jan 26, 2002 08:51 AM
