Ring gapping for boost...
Car: Pending
Engine: LM7
Transmission: 4L80E
Axle/Gears: Unknown
Would a new handheld file be too slow? Would an angle grinder be too fast or too hard to control? I have both, and thought about mounting the grinder in a bench vise.
Opinions?
Opinions?
Engine: 4++,350 & 305 CIs
Re: Ring gapping for boost...
Buy the correct jigs/tools for gapping. You'll be glad you did.
Car: 88GTA
Engine: 5.7TPI
Pretty cool video with the grinder/Jigs
Car: '84 Trans Am
Engine: 357 SBC
Axle/Gears: 10 Bolt 3.73, Torsen Diff
You can also cheat and get a cheaper hand-crank style, cut off or remove the hand cranker, and attach a cordless drill to it. Presto, powered ring file. Just, uh... Be careful. It goes a lot faster than you might think.
How much do you need to take off the rings?
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
As mentioned you will want to buy a ring gap grinder tool. Hand file won't cut it not will a grinder. You need to ensure you are removing material square to the cross section of the ring. Meaning, no bevels, radii, etc.
Car: Pending
Engine: LM7
Transmission: 4L80E
Axle/Gears: Unknown
About what I expected, where's the fun in that? I ask myself, what would the sloppy mechanics do? I'll try the hand file first and report back by posting a link to a video I'll post to YouTube.
Car: 85 Z28
Engine: 93 LT1
Axle/Gears: 3.73 01 SS
A good abrasive will have no problem, a die grinder set at low to medium speed in a vice with a finer type of bit, recheck gap and finish with sandpaper. I do amateur machining and sounds a little scary for a high pressure, temperature sensative, tolerance limited application, but it's not impossible. Would be impressed if you could pull it off and make all of them to within tolerances without driving yourself crazy. Look for a local machine shop supply tool warehouse and grab some good quality grinding/sanding bits/wheels,discs,belts.. whatever works for you.
Trying to do that with some **** from home depot would make a murderer out of a lot of people.
Oh and don't get it too hot. If they're a type of cast iron they can get very brittle.
