msd gapping!
Old Oct 14, 2001 | 11:49 PM
InDa12's's Avatar
msd gapping!
if i put a msd 6al on my 89 350(TBI) can i gap my plugs at .050 for more spark and better detonation?
Old Oct 15, 2001 | 01:33 AM
Tas's Avatar
Tas
yes
-Tas
'89 Formula WS-6
305, TBI, 700R4, P.A.W. 14x3 open element with K&N, Milodon 160* thermo, functional Formula hood, cross-flow Flowmaster, '99z28 rear pipes and tips, Hooker 1-5/8" 50 state legal headers, Dynomax 3" I pipe (PN 44063 and 43248)
Super GRK_Taz World
F-Body Dual Exaust
EFI & Intake Options
AOL IM: superGRtaz
Got Beach?
Old Oct 15, 2001 | 06:12 PM
coolguywalt's Avatar
Car: 89 Turbo Trans Am, '14 Forester XT
Engine: 3.8 Turbo V6
Transmission: 2004-R
Same question, but I have a 305 with the 6AL and a blaster coil...should I widen mine up to .050 or more?
Old Oct 15, 2001 | 09:50 PM
9177's Avatar
yep i did on mine and it made a diff
Old Oct 16, 2001 | 04:42 PM
Done and done!!!
Old Oct 16, 2001 | 05:24 PM
NJ SPEEDER's Avatar
you guys are on the right track with this. but for any body with a stock/ cheapie coil, you will want to avoid this.
the stock coil runs into a lot of probs at higher rpm's keeping up full power. that means you are losing spark current and combustion.
a good coild doesn't cost much if you have an aftermarket ignition box, my accel super stock was only $25 at autozone.
later
tim
91 Camaro RS-LO3,Auto
New Times Coming Soon!
Check Out The East Coast F-Body Nationals Home Page
www.geocities.com/njspeeder
My MAFB.ORG Home Page
www.mycar.net/mafb/registry/detail.cfm?id=299
DSI Racing Home Page
www.geocities.com/foff667
Old Oct 16, 2001 | 05:42 PM
Kyle F's Avatar
YEs you can, I did it.
THough I had a hypertech coil and low resistance MSD wires to so I had no problems at the upper RPMs.
89 Trans Am Turbo 3.8L All stock 43,000 miles #1053 of 1555
Past Thirdgen:
86 Trans Am w/ built 355TPI with SLP goodies and too much other stuff to List. One sweet *** car, wish I would have had a good enough Job to pay insurance on three cars so I could keep it, but for a 89 Turbo Trans Am w/ Low miles, I think I made the right choice!
Old Oct 25, 2001 | 04:55 AM
TBIfly's Avatar
91 RS L03 305 TBI
##### QUESTION #####
Im running a stock ignition with an MSD Blaster Coil on it and stock gapping at .35
should i bump the gap open a bit and is .5 to high without the aftermarket ignition box?
please email me
Old Oct 25, 2001 | 06:41 AM
9177's Avatar
I've heard you can push it to .045 (which is what i think you meant not .45) but have never tried it without my msd box
Old Oct 25, 2001 | 01:15 PM
JPrevost's Avatar
Car: 91 Red Sled
I didn't know so many people didn't know about spark plug gaps.
The most gap you can run the better.
Like the guys said, run a larger coil or the engine will fall flat on it's face at a certain rpm. That max rpm depends on compression, advance, wires, you name it.
, Jon (350 TBI!)
91 Red My website
Old Oct 25, 2001 | 02:20 PM
BahamutRS's Avatar
Hey, I have MSD6A, but if I buy a MSD coil or the Accel super stock coil, will I need to rewire anything from the MSD?
1992 Camaro RS (Auto) 5.0L TBI
Performance mods
NOS (125 HP shot), Dynomax cat-back exhaust, Hedman headers, no cat, custom high beam delete ram air w/ K&N, MSD 6A ignition, MSD 8.5mm plug wires, LT1 camshaft
Soon to be installed:
Edelbrock Perfomer TBI intake, B & M 2200 RPM stall torque converter, Trans Go shift kit, World Products Torquer heads, Ed Wright Fast Chip
Audio
Sony Xplod CDX-M610 head unit, Pioneer 2-way 4x6 front speakers, Pioneer 3-way 6x9 rear speakers, 12 inch Pioneer VCCS PRO subwoofer, QLogic sealed box, Kicker ZR360 amplifier, Lightning Audio 1 farad capacitor
Other
Macewen White Faced Gauges/Shift overlay, A-pillar gauges (Phantom oil pressure, Air/Fuel), 180* thermostat, Window Tint, chrome valve covers, xenon headlights
Old Oct 25, 2001 | 04:05 PM
TBIfly's Avatar
thanks, youre absolutely right, thats what i meant
not fast....not pretty....but has great potential for both.
Old Oct 26, 2001 | 03:56 PM
89RS305's Avatar
I have a question about my MSD wires. I just found out that I'm arking really bad. I just put in a MSD Performance Coil and it helped a little bit, but it's still arking. What else can I do. I have Bosh plugs, accel cap and roater, MSD wire, and now at MSD coil. I think the wires are bad, so I'm gonna try to change them and see what happendes.
Old Oct 26, 2001 | 06:29 PM
JPrevost's Avatar
Car: 91 Red Sled
Definatly sounds like a wire problem. I had the same thing after I did my engine swap. The stupidest thing I ever did was reuse the wires. The rubber cap at the plug was dry rotted and was causing nasty arc. The car didn't like me, new wires, reset timing, thing pulls.
, Jon (350 TBI!)
91 Red My website
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
sreZ28
Oct 22, 2015 08:21 AM
meeklay812
Oct 1, 2015 03:46 PM
86CamaroDan
Sep 29, 2015 10:08 PM
