Sanden A/C compressor
Old Nov 11, 2018 | 03:31 PM
johnw999's Avatar
My Sanden compressor locked up and snapped my drive belt. I replaced the belt, but now I need to buy a new A/C compressor. I bought mine off of ebay. I used the A/C in my car for about 3 hours total. I bought my compressor from ebay, and I think I got scammed.
Where is a good place to buy another A/C compressor?
Is there a shut-off valve that I can install? I'm going to have to recharge the coolant after replacing the A/C pump. Should this happen again, I want to avoid messing with R134.
Old Nov 11, 2018 | 04:25 PM
ULTM8Z's Avatar
Re: Sanden A/C compressor
dont screw around with imitation Sanden compressors or remans, or "Sanden style"...
get an OEM Sanden. I went through two remans before learning my lesson and getting an OEM.
you can still get them on Ebay, but just make sure it's a genuine Sanden.
Old Nov 11, 2018 | 05:56 PM
johnw999's Avatar
Thanks - that’s what I needed to know. I went to Sanden.com . Looks like Vintage Air is an authorized distributor. I think I’ll buy a new compressor from them.
Old Nov 11, 2018 | 07:45 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Dirty Dingo also sells them, as does Kwick performance.
Old Nov 11, 2018 | 08:15 PM
johnw999's Avatar
Thanks - I bought the bracket from Kwik. I’ll check out their website too.
Old Nov 14, 2018 | 07:30 AM
johnw999's Avatar
I bought a Sanden 508 from Vintage Air. Some sites now sell the SD709, but I read that the 508 is better for ls swaps. Is it possible to install a shutoff valve at the compressor? If I run into a problem again, I’d rather not have to deal with refrigerant.
Old Nov 15, 2018 | 04:31 PM
johnw999's Avatar
Old Nov 15, 2018 | 04:32 PM
johnw999's Avatar
The new Sanden compressor and PAG oil have arrived.
Old Nov 15, 2018 | 05:32 PM
ULTM8Z's Avatar
Careful.... Sanden has a specific oil they say to use in their compressors. You may void the warranty if you run something else. SP-15 oil.
Mine actually came pre-loaded with the stuff. Check that as well before adding more oil.
http://www.sanden.com/refrigerantoil.html
Old Nov 16, 2018 | 12:27 PM
johnw999's Avatar
Thanks. I bought vintage air PAG oil, and I thought I saw in a Q&A section that PAG oil had to be added. I looked again, and I must have misread. Vintage Air says their compressors are preloaded with it.
Old Nov 16, 2018 | 02:47 PM
johnw999's Avatar
I found my answer in the bottom of the shipping box. Compressor is good to go.
Old Nov 18, 2018 | 12:52 PM
johnw999's Avatar
I think I figured out why my A/C compressor failed. The Sanden comes prefilled with oil. This cheap copy from China was bone dry when I opened it up.
jstalt
Feb 7, 2017 09:52 PM
Blownz28man
LSX and LTX Parts
18
Jan 28, 2015 09:24 PM
cc 82Z-28
Jul 5, 2010 06:31 PM
gruNT
Oct 10, 2001 06:38 PM
