5.3 LS Swap
Old Dec 15, 2018 | 03:21 PM
92rsmane's Avatar
Car: 1992 Camaro RS
5.3 LS Swap
Hey, I just wanted to know for my 92 camaro will I need to buy an entire tubular K member or can I just buy the motor mounts for the 5.3 ls swap?
Old Dec 15, 2018 | 06:37 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
Re: 5.3 LS Swap
You can just buy the LS swap mounts.
Old Jan 3, 2019 | 11:05 PM
jking78's Avatar
Re: 5.3 LS Swap
What mounts and oil pan did you use
Old Jan 4, 2019 | 09:38 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: 5.3 LS Swap
Lots of options from many vendors. Take some time to rear up on the stickies up top which will help guide you. Most choose to run the f-body LS1 oil pan but there are other options as well (Holley). You can use your existing K-member but will be required to notch it it you run the traditional low mount AC compressor.
Old Jan 4, 2019 | 12:11 PM
Billgluckman's Avatar
Re: 5.3 LS Swap
I used cheap 1” set back adapter plates that allowed me to use factory sbc motor mounts. Cost was $30-$50.
No need to swap k member. I used a factory ls1 (f body) oil pan. I did not notch my kmember because I plan on running aftermarket accessories which will mount ac compressor on the top passenger side like a third gen with a sbc.
Old Jan 4, 2019 | 12:31 PM
battmann's Avatar
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
Re: 5.3 LS Swap
I'm using a stock LS1 F-body oil pan with UMI motor mounts (both the engine and body side). I have about 1/2" clearance everywhere between the oil pan and stock k-member. My car doesn't have A/C so I didn't have to modify the k-member. I originally tried using Spohn LS swap motor mounts and the oil pan was right on the stock k-member. I wouldn't recommend using Spohn products.
camaro6spd
Nov 11, 2001 08:52 AM
86TpiTransAm
Feb 28, 2001 08:22 AM
EO273KiD
Nov 4, 2000 02:20 PM
