C5 A&A bracket and a/c?
Old Jul 11, 2019 | 06:55 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Hey guys I’m looking into putting a A&A C5 blower and bracket on my thirdgen I’ve seen guys have used this on our cars. But I was wondering has anyone been able to use the corvette a/c on there car? Or would I be able to space out the supercharger bracket to align to fbody accessories and be good?
Old Jul 13, 2019 | 10:01 PM
Lonnie P's Avatar
Car: 91 Formula
Engine: 2012 LS9
Transmission: 4L80E
Axle/Gears: Strange 60 3.54:1
Re: C5 A&A bracket and a/c?
I do not have the Vette Supercharger on my car, but I do have the Corvette accessory brackets & AC on my Firebird.
Yes it will fit without much problem... notch the frame & you will need a custom power steering hose & fitting.
Old Jul 14, 2019 | 03:24 AM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
What type of engine mounts are you using tho? I’ve heard that when using Spohn mounts since it mounts engine on stock location it don’t give enough clearance on ac compressor
Old Jul 14, 2019 | 07:26 AM
Lonnie P's Avatar
Car: 91 Formula
Engine: 2012 LS9
Transmission: 4L80E
I used the mounts from Hawks. The engine is not moved forward as I did not have to modify the cross member for oil pan clearance.
I actually had the same plans to put a C5 Charger on my car.
After reading all the "It wont fit" responses I was nervous, but it ended up being rather easy.
I bought a factory Corvette AC line & changed the ends off to mate with the 3rd gen connections.
Old Jul 14, 2019 | 01:19 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Hawks uses Spohn mounts I believe so all you had to do was the normal notching as the fbody compressor needs then? Or did you have to trim more? This is really good news for me because if I can fit corvette accessories I would just run that and a 10rib setup on my car as well.
Old Jul 14, 2019 | 01:31 PM
Lonnie P's Avatar
Car: 91 Formula
Engine: 2012 LS9
Transmission: 4L80E
Yes they are the Spohn mounts that I got from Hawks, the brand wasn't listed but the photos are the same. You do have to notch slightly more.... look at the pic posted, as the Vette accessories are further back.
I actually bent the mount ears slightly to move the engine back a little further due to the headers being rather tight, maybe an additional 1/2".
It's best to suspend the engine & bolt the cross member to it for a trial fit before install.
You have to cut closer to the coil spring as the AC lines connect to the side instead of the rear of the compressor.
Old Jul 14, 2019 | 03:46 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Oh okay l see what you mean now. I bought the ac lines from hawks for the fbody compressor so maybe those lines would not fit with Vette compressor. You have any pics by any chance with your compressor installed and the lines.
Old Jul 14, 2019 | 06:10 PM
Lonnie P's Avatar
Car: 91 Formula
Engine: 2012 LS9
Transmission: 4L80E
The F-body lines are different.
Here is how the lines are oriented... I don't have a picture of the line connected.
Old Jul 14, 2019 | 09:58 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Oh okay well atleast that’s good to know. I emailed A&A to see if they had spacers for the brackets if not I will for sure do what you did I didn’t know it was possible was there any issues with any of the steering stuff?
Old Jul 14, 2019 | 10:45 PM
Lonnie P's Avatar
Car: 91 Formula
Engine: 2012 LS9
Transmission: 4L80E
No... Detroit speed makes a PS pump adapter fitting for better pulley clearance & you have to get a pressure hose made.
Accessories clear everything under the hood. No clearance issues with steering box clearance.
TPIMonteLS
Jun 23, 2012 06:12 PM
Rob 97 Z28
Carburetors
May 4, 2010 08:29 PM
killacamaro
Feb 24, 2008 02:45 PM
