408 stroker .. stock tpi air box?
Old Mar 8, 2020 | 08:56 PM
91z28 98ta's Avatar
Car: 89 iroc 98 T/A
Engine: LSX
Currently I have a ls1 w/cam in my car, swapping to a 408 with heads cam intake will the stock tpi air box be restrictive should I make a cold air intake? I like the stock look and fit but if restrictive it’s gone. Thanks for any input
Old Mar 8, 2020 | 09:10 PM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Re: 408 stroker .. stock tpi air box?
Waaaaay restrictive. But you can give it a try and look at your MAP sensor values at wide open throttle.
A 4 inch intake and very large filter was on the hairy edge for my 427 stroker. I had to bump up to a 5 inch intake with the LS7.
Old Mar 8, 2020 | 09:27 PM
soloc4's Avatar
Car: 84 Z28, 92 C4 suspension F&R, ABS
Engine: 408 LS2, CNC LS3 heads, Comp Cam
Transmission: Magnum F, RTX clutch, Tick shifter
Axle/Gears: DANA 44 IRS, Tru Trac, 3:73 gears
This is a 408 LS2 with CNC’d LS3 heads and an aggressive cam. The CAI is 4”, which is the minimum for this motor as QuickTrip stated. You’re not going to want to chock that motor. I’m also running a dual 3” exhaust on my motor.
Old Mar 10, 2020 | 06:02 AM
91z28 98ta's Avatar
Car: 89 iroc 98 T/A
Engine: LSX
Thanks for the help ..I think I’m gonna fab me a 4” cold air intake for sure
Old Mar 10, 2020 | 06:04 AM
91z28 98ta's Avatar
Car: 89 iroc 98 T/A
Engine: LSX
what MAF did you use ..the LS3 style?
Old Mar 10, 2020 | 06:09 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
If you built a ram air box to forcefeed the tpi y lid, it would work decent. The Y only flows around mid 700’s cfm. You can custom make one a bit taller like Chad Speier is doing for his 530 hp 379. But its alot of work
a good air intake is better idea tho
Old Mar 10, 2020 | 07:02 AM
soloc4's Avatar
Yes, it is the blade style. I don't remember where I got the aluminum adapter for the aluminum tube, but shouldn't be that hard to find one. I believe the wiring conversion is on this forum somewhere.
Old Mar 10, 2020 | 08:41 AM
427seven's Avatar
Car: 1989 Firebird GTA
Engine: Motown Aluminum 427
Transmission: TH400/GVO
When yer engine is moving enuf air to feed those ci, you need 4"-5" AND high pressure area of the car, higher rpm=bigger inlet
Old Mar 10, 2020 | 09:57 AM
skinny z's Avatar
I say Chad's efforts were well worth it.
https://www.thirdgen.org/forums/fabrication/768690-my-cold-air-intake.html
That he could bench flow his creation lends some credibility to the project. What I found really interesting is his statement that the air filters represented zero restriction. This contrary to what I've read from tech articles and K&N but who am I to argue with a flow bench.
Roachjr
Oct 17, 2009 10:23 AM
kowboy59
Jul 10, 2007 01:20 AM
Red86TPITransAm
Feb 1, 2007 05:04 PM
