Where to get new fuel lines?
Old Dec 23, 2020 | 06:05 PM
Connor Bartley's Avatar
Car: 1989 Camaro RS
Engine: 5.3 LS
Transmission: Powerglide
Hello, me again. After a break from my 5.3 swap, finally got some money to throw at it. I see that my fuel lines have rusted and cracked under the hood. I am getting a new sending unit also. Where in the WORLD do i get the 3 fuel lines? That go from the sending unit lines, to rubber hose, back to METAL lines? Can not find them anywhere.
Old Dec 23, 2020 | 07:30 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Where to get new fuel lines?
SS tubes or inline tubing both sell kits.
Www.inlinetube.com
https://www.sstubes.com/
aliceempire's Avatar
Transmission: T-5, TH350, T-5
The rubber pressure and return lines that go from chassis to engine? Most guys make their own using braided lines and AN fittings. And as pointed out by Shifty, those kits are available.
Old Dec 23, 2020 | 08:16 PM
Car: 1989 Camaro RS
Engine: 5.3 LS
So im guessing this is going to be expensive, seems how they only sell 1 piece at a time? I dont know which i need because there are 3 on my camaro. Sorry im really uneducated on fuel line..
Old Dec 23, 2020 | 08:27 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
They sell the individual segments just like your car has now. I think they sell a complete kit as well. Might be worth a phone call. I've done business with both and the equally helpful.
Old Dec 23, 2020 | 08:28 PM
Car: 1989 Camaro RS
Engine: 5.3 LS
phone call with you or the company XD
Old Dec 23, 2020 | 08:31 PM
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
With SS tube or inline tube. At the end of the day you're going to want a 3/8"'s (-6an) feed and return line. If you are going to make north of 700hp than -8 would be better. You could also run your own lines with bulk fuel line. I'm sure you could save some coin, albeit at the expense of learning as you go.
Old Dec 23, 2020 | 08:42 PM
Car: 1989 Camaro RS
Engine: 5.3 LS
okay thank you so much, very helpful, found what i needed
mlopezformula
Jun 14, 2011 11:03 PM
98_LS1
Jul 13, 2006 10:53 AM
i8myz28
May 26, 2006 08:27 PM
